Kenmore Washer/Dryer Combo 417.90862990 - Drooping Drum
Kenmore combo 417.90862990
4 replies to this topic
#1 moto377
moto377
    Ikkō-ikki
  • 57 posts
Posted 14 July 2012 - 04:33 PM
I have a Kenmore combo unit, model number 417.90862990. The dryer drum is loose and droops downward. I believe this is likely the dryer bearing, but I am just a grasshopper and looking for Samurai's input. If so, can you point me to the bearing part #? And, if a maintenence kit happens to exist for the dryer drum, can you point that out as well?
Thanks!
  • 24,352 posts
Posted 14 July 2012 - 04:40 PM
Yes, drum support glides in the rear drum bearing are you're prime suspects. The following part links also have videos for how to replace them.
Drum bearing ==> http://www.repaircli...er=417.90862990
Front drum glides ==> http://www.repaircli...er=417.90862990
#3 moto377
moto377
    Ikkō-ikki
  • 57 posts
Posted 14 July 2012 - 05:12 PM
I thought I saw a "maintenence kit" for some models. Does one exist for this unit? it seemed more cost effective to buy the bearing, drum glides, etc. together. Again thanks and I will be placing an order for parts tonight!
  • 24,352 posts
Posted 14 July 2012 - 07:00 PM
You are correct, sir! Here is the maintenance kit that you seek ==> http://www.repaircli...4461262/1261075
#5 moto377
moto377
    Ikkō-ikki
  • 57 posts
Posted 14 July 2012 - 07:25 PM
Thank you!!!
And in between your favorite brews, can you take a look at this post at:
http://appliantology...atorspin-cycle/
I am hoping to do one parts order - one for the dryer and one for the washer issue in the post above.
Edited by moto377, 14 July 2012 - 07:29 PM.
