Two Handy & Expeditious Techniques for Troubleshooting a Gas Dryer Burner that Won't Fire Up
Gas dryer burner troubleshoot
2 replies to this topic
#1 Samurai Appliance Repair Man
  • 24,328 posts
Posted 15 July 2012 - 02:30 PM
Two very common troubleshooting techniques that should be in every Appliantologist's toolbox are the non-contact voltage sensing light stick and the humble jumper wire.
You'll occasionally hear purists and other snobs ignorantly poo-poo the voltage light stick. But properly used with an understanding of its limitations and capabilities, the voltage light stick can be a tremendous time saver on service calls.
Strategic use of the jumper wire is a great way to by-pass suspected-bad parts to see if proper function is thereby restored.
This video demonstrates and explains the proper use of both of these time-saving and time-honored troubleshooting techniques that should be part of every Appliantologist's repair arsenal, both professionals and DIYers. (This particular dryer is a Whirlpool-built Kenmore but all gas dryers work the same way so the same techniques apply to all brands; the variations will be in disassembly and the locations of some components like the thermal fuse.)
Here's a good non-contact voltage sensing light stick like the one I used in the video ==> http://www.repaircli...942?RCAID=24038
And here's the thermal fuse I installed to fix this dryer: http://www.repaircli...986?RCAID=24038
You can find whatever appliance part you need through the parts search box right here at The Appliantology Academy. No harm in buying and trying with our 365-day, no-hassle return policy, even on electrical parts that were installed!
Subscribe to our FREE, award-winning newsletter, Appliantology: The Oracle of Appliance Enlightenment ==>http://newsletter.appliantology.org and download your free report on appliance brand recommendations! Every issue is jam-packed with appliance repair tips and inside information direct from the Samurai's fingertips to your engorged and tingling eyeballs.
The Appliance Guru provides prompt, convenient service in the following towns in New Hampshire: New London, Elkins, Wilmot, Springfield, Georges Mills, Sunapee, Mt. Sunapee, Newbury, Sutton, Bradford, Warner, Grantham, and the Eastman Community. Visit our website for more info and a discount coupon on your next service call: ==> http://applianceguru.com
#2 RegUS_PatOff
  • 30,269 posts
Posted 15 July 2012 - 03:58 PM
... the non-contact voltage sensing light stick
... You'll occasionally hear purists and other snobs ignorantly poo-poo the voltage light stick.
just a reminder, appliances sometimes supply the L1 power through the circuit
and it will switch (control) the neutral line.
The light-stick will illuminate even if there is no (complete) power supplied to the part under test..
  • 24,328 posts
Posted 15 July 2012 - 04:02 PM
Hence the admonition to understand its limitations. In the hands of a skilled servicer or knowledgeable DIYer, however, the noncontact voltage light stick is a powerful troubleshooting tool.
Also tagged with one or more of these keywords: Gas dryer, burner, troubleshoot
