True, but that one didn't have a "delicate" cycle.
I believe it did...
from the Lowes description:
8 automatic cycles including Normal Extra Heavy, Gentle and Permanent Press to handle a variety of fabric types and soil levels
Posted 03 January 2013 - 05:30 PM
I believe it did...
Posted 03 January 2013 - 06:45 PM
I believe it did...
Ok, I missed that. Didn't spend much time reading it, since the inventory is gone, according to...
no longer made ..
dwindling inventory seems to have vanished
2 years ago, NEW as low as $ 249 on sale
http://appliantology...d-washer-dryer/
The one that's available now is the Amana, and I need to check on it to see if it's direct drive or the new style. And if the new style, is that good, or bad? Or, should I repair my LG Tromm?
Jack
Posted 03 January 2013 - 09:30 PM
If repairing the WM2277 washer is your decision---you're in the right place for assistance :)
Edited by john63, 03 January 2013 - 09:32 PM.
Posted 03 January 2013 - 09:35 PM
Huh? Okay, you edited, now it's complete.
Alrighty, I was trying to assess whether it was worth repairing, but I'll approach it from the assumption that it is, and I should...
I looked up the bearing on this site, and there was an advisory that I should buy the bearing and rear drum as an assembly. That part was not listed. Dead end?
Jack
Posted 03 January 2013 - 09:54 PM
The BEARINGS can be replaced either as a sub-assembly (rear tub half shell) or the BEARINGS and SEAL can be replaced.
The following parts will be needed:
1) Stainless steel INNER DRUM (3045ER1006E)
2) Tub O-Ring (4036ER4001B)
3) Rear Tub/Bearing Assy (AJQ35154201) or instead of the rear shell...
a) Inner Bearing (4280FR4048L)
b) Outer Bearing (4280FR4048E)
c) Bearing Seal (4036ER2004A)
Edited by Samurai Appliance Repair Man, 04 January 2013 - 04:00 PM.
Added parts links.
Posted 03 January 2013 - 09:59 PM
Well, that puts the parts/shipping somewhere around $500, and the S/S inner drum isn't even in stock. Thanks for the guidance. Looks like it's time to replace it.
Jack
