Maytag Neptune FL washer MAH8700AWW won't take back drive belt
7 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 809 posts
  • Flavorite Brew:Guinness Stout
Posted 17 July 2012 - 11:27 AM
To anyone with experience,
Using the Samurai's posts about E3 codes for the Maytag Neptune (http://appliantology...-be-error-code/ ; http://appliantology...-e3-error-code/ ), I successfully diagnosed the motor failure in this washer. Now, I can't the drive belt back on; no grotesque brown staining in the rear (http://fixitnow.com/...on-main-pulley/). What do I do?
Thanks in advance,
Tyrus (RedToryTy)
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 809 posts
Posted 17 July 2012 - 12:18 PM
Here's the video:
Mr. Tyrus Lee Smith
706-778-3411
#3 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
  • Flavorite Brew:yeunling
Posted 17 July 2012 - 05:09 PM
either the motor is not in right, or its the wrong motor or the bearings are bad in the tub allowing the big pully to cock to the side
#4 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 699 posts
Posted 17 July 2012 - 07:49 PM
The belt has to be in the exact grooves for allignment, can't be 1 groove off.
Edited by SANTA, 17 July 2012 - 07:50 PM.
  • 24,698 posts
Posted 17 July 2012 - 09:50 PM
Good video! This looks like a bad bearing to me. The stains are just one of the outward signs of an extreme case of worn bearings. But the bearings can also wear in such a way that they throw the belt because the worn bearing throws the pulley off true and that may be the only evidence.
#6 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 809 posts
Posted 18 July 2012 - 10:32 AM
This is one time I'm glad our benevolent overlord was wrong. Removed the motor, reinstalled it with the bushings correctly positioned, and reconnected power supply. Performed a board input test--passed with flying colors! Next, to double check myself, ran a load of queen-sized bed clothes--success!
Mr. Tyrus Lee Smith
706-778-3411
  • 24,698 posts
Posted 18 July 2012 - 08:25 PM
Run that part about "reinstalled it with the bushings correctly positioned" by me again, budrow-- I musta missed that in your first post.
#8 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 809 posts
Posted 19 July 2012 - 05:31 AM
There are two holes at the right-rear mounting spot; I initially had the bushing in the closest hole. After moving the bushing to the outer hole, the motor mounted up perfectly. Will look for a pic (didn't take any).
Mr. Tyrus Lee Smith
706-778-3411
