Amana Washer (Model LWA50AW) - Agitation issue
7 replies to this topic
#1 Bamabd90
Bamabd90
  • 2 posts
Posted 17 July 2012 - 04:08 PM
My Amana washer just basically humms/buzzes when it reaches the initial agitation cycle after filling with water. It drains, spins, etc if you move the dial past the agitation sections of the cycles.
Any assistance is soooooooooo appreciated.
Thanks!
#2 sh2sh2
sh2sh2
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 756 posts
  • Flavorite Brew:yeunling
Posted 17 July 2012 - 05:07 PM
first thing i would do is take off the belt and see if the trans pully spins both ways, one way spins the tub, one way agitates, if it wont turn the agitate way then its time for a new tranny
#3 Bamabd90
Bamabd90
  • 2 posts
Posted 17 July 2012 - 05:50 PM
Thanks for the tip! I will check that out when I get home tonight. :)
In the event it is the tranny - any idea how much a replacement would cost and if it is fairly easy to replace?
#4 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 756 posts
Posted 17 July 2012 - 06:48 PM
also check to make sure nothing is stuck under the adgiatator
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 July 2012 - 09:36 PM
... In the event it is the tranny - any idea how much a replacement would cost
http://www.repaircli...tDetail/1480335
#6 Scottthewolf
Scottthewolf
    Senpai
  • 2,944 posts
Posted 17 July 2012 - 11:34 PM
That's the wrong transmission, Reg. This is a Speed Queen style Amana washer.
Here is the link to the correct transmission for this washer, which for the price of it , I would never even bother with unless you have some sentimental attachment to the washer.
http://www.repaircli...2002178/1032765
Scott Wolf
#7 Scottthewolf
Scottthewolf
    Senpai
  • 2,944 posts
Posted 17 July 2012 - 11:40 PM
If the motor won't run with the belt off the transmission pulley, but will run fine in spin, the timer could be the problem.
Scott Wolf
#8 RegUS_PatOff
  • 33,588 posts
Posted 18 July 2012 - 12:07 AM
... That's the wrong transmission, Reg. This is a Speed Queen style Amana washer.
ahh, yes, I see...
there are some replaceable parts (Image 2)
(although we're not sure the Transmission is bad)
