  • Announcements
Sign in to follow this
Followers 0
too many main boards Kitchenaid KSCS25FTMS00
5 posts in this topic
Okay....two main boards listed. one seems to be sold out (probably the one I need)..which one can cause ice dispenser to go out and affect cooling as well. Haven't been to customer's house but this is the symptom he is experiencing
...which one can cause ice dispenser to go out and affect cooling as well.
can't dispense Ice if it isn't making any .. :whistling:
May need to check to see if the Compressor is running
OR check the Inverter input / output voltages
Do you need the tech sheets ?
lol, no but the problem s that it is not dispensing ice that is already made.
... can cause ice dispenser to go out and affect cooling as well.
Freezer Compartment Door Switch ... ?
It's actually the water dispenser that is not working. Customer called back and said water dispenser and fridge is now cooling properly..so it's an intermittent problem.....
great idea!
Followers 0
