Maytag washing machine model MHW2000AWW not draining completely
#1
Posted 24 July 2012 - 08:57 AM
The hoses were checked for debris/blockage, no issue there. The pump was disassembled and it was full of sand and lint. Pump was cleaned, cycle was ran with nothing in it and there was no water in the machine. Thinking the issue was fixed, did regular load with clothing, still very wet. Is it possible that the pump is just burned out from the debris (sand, lint) that was clogging the pump? Or does this sound like a separate issue altogether. Want to order pump, but don’t to waste time or money if that is not the issue.
Thank you kindly in advance for your assistance.
#2
Posted 24 July 2012 - 09:01 AM
The other thing to do is disconnect the drain hose from the pump and then pucker up and blow like a fish through the drain hose. You should clear and initial slug of water and then it should blow free. This will positively confirm that the drain hose is clear.
It is also possible, given the debris that you describe, that the pump has become impaired and is not turning at full speed. If this is the case, then you would replace the pump. ==> http://www.repaircli...mber=MHW2000AWW
#3
Posted 24 July 2012 - 09:41 AM
#4
Posted 27 July 2012 - 08:18 AM
#5
Posted 27 July 2012 - 08:37 AM
#6
Posted 27 July 2012 - 09:11 AM
#7
Posted 27 July 2012 - 09:14 AM
Does the Washer actually Spin good ?Let water into the drum and then do a pump out while lifting the drain hose enough so that you can observe the discharge stream.
The discharge stream should be fullbore and turbulent.
If it is smooth wall and it comes out and tapers down then you either have a restriction in the drain hose ...
#8
Posted 27 July 2012 - 09:17 AM
#9
Posted 27 July 2012 - 09:28 AM
Let water into the drum and then do a pump out while lifting the drain hose enough so that you can observe the discharge stream. The discharge stream should be fullbore and turbulent. If it is smooth wall and it comes out and tapers down then you either have a restriction in the drain hose ...
#10
Posted 28 July 2012 - 10:23 AM
#11
Posted 28 July 2012 - 09:36 PM
Easy one first -- check the drain hose. Most people have too much drain hose in their stand pipe, and once the standpipe starts slowing down, the water will back up into the washer. If you have more than 6" of hose in the standpipe, correct, and retry your experiment.
If that doesn't work, sit there and watch your drain and spin cycle. That's usually about 12-13 minutes long. It's pretty boring, but it's actually more interesting than a re-run of Friends.
What you very well may see is that the machine spins for two or three minutes and then never really gets going again. You may also see the unit just give up and quit spinning 5 or 6 minutes prematurely. If that happens, you may have a bad control board or a bad motor controller. How you test that without having a subscription to the Maytag Techline is a question better asked of the Samurai Himself.
If you see a whole drain and spin cycle and you don't have any issues -- no shuddering, no early check-out, no half-hearted spin -- check the tub outlet hose, the one that leads to the drain pump, back where it attaches to the tub. You may find an physical obstruction there, like a sock or a buildup of lint. (In the field, this is actually the one I would do second, but I'm saving it for last for you because this is going to be a pain in the arse if you're not used to taking these machines apart.)
Also tagged with one or more of these keywords: maytag, washing machine, neptune, MHW2000AWW, not draining
