whirlpool dryer gew9200lwo error code e1
8 replies to this topic
#1 serv.man
serv.man
    Ikkō-ikki
  • Chief Appliantologist
  • 30 posts
  • Flavorite Brew:martini
Posted 24 July 2012 - 01:00 PM
Unit came in complaint no heat. Replaced high limit and thermal fuse and heater. Used 279816 kit also the thermistor. But unit is still shuting down in about 1 minute and displaying e1. Is the 279816 kit compatible with this unit. HERB
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 24 July 2012 - 02:22 PM
The thermistor in that kit is the inlet thermistor ...prolly have a bad OUTLET thermistor.
On the blower housing.
#3 RegUS_PatOff
  • 30,198 posts
Posted 24 July 2012 - 02:31 PM
279816 is Thermal Fuse = 309F and Hi-Limit = 250F
you should have
279973 352F & 295C
http://www.repaircli...rtDetail/897710
E1 is open Thermistor (should read about 10k OHMs)
http://www.repaircli...tDetail/1181075
#4 serv.man
serv.man
    Ikkō-ikki
  • 30 posts
Posted 25 July 2012 - 10:35 AM
Thanks for your responce. I replaced the thermal fuse and the high limit with correct parts but unit still shuts down in about one minute and displays e1. Also replaced thermistor. do you have any other ideas. HERB
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
Posted 25 July 2012 - 11:24 AM
Nuthin left but harness and control...
#6 RegUS_PatOff
  • 30,198 posts
Posted 25 July 2012 - 11:55 AM
check where the Thermistor plugs into the Main Control
about
50°F 20k
60°F 15k
70°F 12k
80°F 9k
90°F 7.5k
100°F 6k
if OK ..
bad Main Controller
http://www.repaircli...tDetail/1028315
#7 serv.man
serv.man
    Ikkō-ikki
  • 30 posts
Posted 25 July 2012 - 02:56 PM
THANKS GUYS. FOUND OPEH WIRE BETWEEN THERMISTOR AND CONTROL BOARD. HERB
  • 24,214 posts
Posted 26 July 2012 - 08:21 AM
Good find, serv! Share with us your technique for finding that boogar.
#9 nickfixit
nickfixit
  • 1,964 posts
Posted 29 July 2012 - 11:11 AM
Finding the break in the harness... that will separate the men from the boys. Checking the thermister from the control is the way to go.
Nice work Serv.man
