Maytag Dryer Model MDE2400AYW-No Heat
20 replies to this topic
#1 mntn1422
mntn1422
  • 8 posts
  • Flavorite Brew:chimay
Posted 26 July 2012 - 08:42 PM
New to the site.
I have a Maytag Dryer that won't heat. Already disassembled and checked resistance of element, thermal switches and get .2 ohms on all. There is, what I'm assuming is a thermostat in the exhaust that is reading 57K ohms. could that be the problem?
#2 RegUS_PatOff
  • 30,708 posts
Posted 26 July 2012 - 08:58 PM
... assuming is a thermostat in the exhaust that is reading 57K ohms.
Thermistor in Exhaust 57k OHMs is OK
1) check and re-set the House Circuit Breakers for the Dryer
2) measure 120v and 240v at the Dryer Cord Terminal Strip
#3 mntn1422
mntn1422
  • 8 posts
Posted 26 July 2012 - 09:22 PM
good at t-strip. still blowing cold as a witches @#!
is there a self diagnostic test for this model?
#4 RegUS_PatOff
  • 30,708 posts
Posted 26 July 2012 - 09:37 PM
... is there a self diagnostic test for this model?
no
While running a Dryer Heat Cycle
check voltage across the Controller Terminals
BLU 1 to BLU 2 =
WHT 1 to WHT 2 =
#5 mntn1422
mntn1422
  • 8 posts
Posted 26 July 2012 - 10:18 PM
0 vac on both.
Is there a PCB print available?
stupid question?
#6 RegUS_PatOff
  • 30,708 posts
Posted 26 July 2012 - 10:25 PM
... Is there a PCB print available?
no
now test
BLU 1 to WHT 1 =
BLU 2 to WHT 2 =
#7 mntn1422
mntn1422
  • 8 posts
Posted 26 July 2012 - 10:32 PM
246.9 vac on both
with or without heat cycle on
#8 RegUS_PatOff
  • 30,708 posts
voltage across each of the Thermostats (not the Thermistor)
#9 mntn1422
mntn1422
  • 8 posts
Posted 26 July 2012 - 10:38 PM
0 vac heat cycle or not on both
#10 RegUS_PatOff
  • 30,708 posts
Posted 26 July 2012 - 10:44 PM
then there should be 240v at the Heater
Terminal Strip
pins 1 to 5
pins 1 to 6
#11 mntn1422
mntn1422
  • 8 posts
Posted 26 July 2012 - 10:53 PM
My deepest apologies Sensei. When you had me check the voltage at the thermostats, I realized I hadn't actually checked the resistance across the element, as I'd thought earlier. It's wide open.
Would you happen to have the part number?
Edited by mntn1422, 26 July 2012 - 10:58 PM.
#12 RegUS_PatOff
  • 30,708 posts
Posted 26 July 2012 - 11:00 PM
http://www.repaircli...tDetail/1067839
#13 mntn1422
mntn1422
  • 8 posts
Posted 26 July 2012 - 11:03 PM
Outstanding! I'm sure to be a regular here. I'm so thankful that I found this site. Definitely worth the membership.
#14 RegUS_PatOff
  • 30,708 posts
Posted 26 July 2012 - 11:09 PM
:woohoo:
(also moving post from Kitchen to Laundry forum)
#15 mntn1422
mntn1422
  • 8 posts
Posted 29 July 2012 - 03:01 PM
me again... replaced element and dryer is heating fine, but now there is a burning smell and there is smoke in the drum when I open the door. there was a lot of lent inside the chassis and I cleaned most of it out. Is this common?
#16 RegUS_PatOff
  • 30,708 posts
Posted 29 July 2012 - 03:15 PM
maybe... if the lint has been blown loose and has now reached the Heating Element ..
Have you checked the temperatures at the Dryer Vent ?
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#17 Samurai Appliance Repair Man
  • 24,721 posts
Posted 29 July 2012 - 04:11 PM
Maybe you have a case of this...
#18 jb8103
jb8103
    Kohai
  • Chief Appliantologist
  • 459 posts
  • Flavorite Brew:Ginger ale
Posted 29 July 2012 - 08:38 PM
Yikes. Gotta be a GE.
First, do no harm.
#19 Samurai Appliance Repair Man
  • 24,721 posts
Posted 29 July 2012 - 09:56 PM
Nawsir, that there's an abused Maytag RE: this post ==> http://appliantology...g-drying-times/
#20 Budget Appliance Repair
  • 4,032 posts
Posted 30 July 2012 - 06:17 AM
That's definitely not an old Maytag, it's the Whirlpool DOTT dryer, maybe one of the newer Maytag labeled Whirlpools.
These DOTT style dryers get very serious lint build up if the user doesn't clean the lint screen on a regular basis, (IE: after every load).
I see the worst lint build up then any other style dryer in these and have ran across many of the gas models that the lint has built up so bad the burner has ignited the lint and the top surface of the lint is all burnt, very lucky they didn't have a dryer fire and burn there house down.
Edited by Budget Appliance Repair, 30 July 2012 - 06:21 AM.
William Burk (Willie)
Eureka, CA 95501
