LG MOD. WMO532HW WASHER
WONT RUN
3 replies to this topic
#1 serv.man
serv.man
    Ikkō-ikki
  • Chief Appliantologist
  • 33 posts
  • Flavorite Brew:martini
Posted 30 July 2012 - 02:11 PM
Customer said unit would not run. Tried to run service test at third test high speed spin it went to 1000 rpms but it never stoped so I could move to the next test.The test sheet in bold red letters said not to proceed until spin stoped. Which it never did. Have had very little experiance on LG washers. any one had this problem. Every test worked up to this point. HERB
  • 24,692 posts
Posted 31 July 2012 - 06:35 AM
I PMed you the service manual on this washer. I also checked the LG site for a bulletin on this one and didn't find any bulletins on this problem. So, absent any other specific instructions from LG, you have to go by what you've found, which is a main control board not implementing the diagnostic procedure correctly. ==> http://www.repaircli...Number=WM0532HW
Have you tried retrieving any stored error codes in the control?
#3 serv.man
serv.man
    Ikkō-ikki
  • 33 posts
Posted 02 August 2012 - 06:58 AM
NoI have not tried to retrive error codes. Am not sure how to do that.HERB
  • 24,692 posts
Posted 02 August 2012 - 01:57 PM
Check the service manual I PMed you-- has the procedure in there.
