LG LDS5811 End of wash it turns on the water solenoid
LDS5811 5811 LD S5811
3 replies to this topic
#1 BBQTexas
BBQTexas
  • Chief Appliantologist
  • 3 posts
  • Flavorite Brew:Killian Red, Suntory, Shiner Bock
Posted 31 July 2012 - 12:38 PM
I've done some searching in the forum about this model but haven't seen a similar issue that I'm facing now.
A couple years ago I had the infamous melted wiring harness problem - repaired a couple wires in the ribbon and insulated it. So far all has been well – until now.
When the unit is started it fills just fine, washes and rinses but when it goes into the last drain cycle just before drying the fill starts again and never shuts off. At first I thought maybe the solenoid got some gunk in it and kept it open. However, during the normal wash cycle the solenoid comes on and shuts off normally.
So the water begins to fill and never stops. The washer has the drain pump on also so it never overfills. But, yes there is a but, it leaks from the bottom when it goes into this ghost fill cycle.
Makes no sense to me. Maybe of you have seen this before.
SN: 605KW00326
Edited by Samurai Appliance Repair Man, 31 July 2012 - 09:17 PM.
Cheers
  • 24,218 posts
Posted 31 July 2012 - 09:20 PM
Not seen this problem but PMed you the service manual in case it helps.
#3 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 894 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 01 August 2012 - 05:39 AM
Check for gookus in the sensor assembly and in the tube from the guide assembly to the pump. Not the exact problem as descibed above, but I have seen this cause a fill and immediate drain issue... The sensor doesn't sense the fill and starts the drain pump to prevent over-fill...but usually at the beginning of a cycle.
Mother Teresa
#4 BBQTexas
BBQTexas
  • 3 posts
Posted 01 August 2012 - 12:28 PM
Samurai - The SM will definately help. Thanks
Chat... I'll check for the gookus. Me no like gookus.
Cheers
Also tagged with one or more of these keywords: LDS5811, 5811, LD S5811
