Whirlpool Gas Estate Dryer Ignitor Glows, Shuts Off
12 replies to this topic
#1 tamfflcommissioner
tamfflcommissioner
  • 14 posts
Posted 02 August 2012 - 03:36 PM
Hello Sensei, Apprentices, Masters, Grasshoppers,
I have a Whirlpool Gas Estate Dryer. The ignitor glows, then shuts off. Intermittently.
I have read this page: http://fixitnow.com/...in-a-gas-dryer/ and THINK my coils are fine. I I am using a Sperry analog multimeter and can't tell if I have the right resistance.
I have tested all the components here: http://fixitnow.com/...n-a-gas-dryer/. (Igniter, Radiant sensor) All check out fine.
Found THIS post: http://appliantology...__fromsearch__1 Everything fine except the cycling thermostat bias heater. I think. I tested the Secondary contacts (that had the purple wires) against the Main contacts (that had the red wire) and nothing happened.
Is it likely that the cycling thermostat would case the igniter to glow, then shut off intermittently?
Or am I over thinking it (and my skill with the multimeter)?
Many thanks for all the help thus far!
-Jeff
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 August 2012 - 03:49 PM
model number ?
How long does the Ignitor glow ?
How long does it stay OFF ?
#3 tamfflcommissioner
tamfflcommissioner
  • 14 posts
Posted 02 August 2012 - 04:03 PM
Model is: TGDX640JQ2
Glows for < 10 seconds. Sometimes it ignites.
I have not observed how long it stays off.
#4 RegUS_PatOff
  • 33,588 posts
Posted 02 August 2012 - 04:14 PM
When it ignites, how long does the Flame stay ON ?
has this Dryer worked OK for you up till now at this location ?
sounds like weak Coils
(can't be determined with a resistance test)
common problem, cheap fix
http://www.repaircli...PartDetail/3479
#5 tamfflcommissioner
tamfflcommissioner
  • 14 posts
Posted 02 August 2012 - 04:19 PM
Good question. I have not observed how long the flame stays on either.
Dryer has been acting up for about a month. Before that, it was fine.
Ok, so no way to test the coils huh? So just buy 'em and swap out?
#6 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 02 August 2012 - 07:44 PM
Do the coils REG suggested.
#7 Jimi
Jimi
    Ikkō-ikki
  • Chief Appliantologist
  • 21 posts
Posted 02 August 2012 - 09:09 PM
I have seen these coils fire and run three times before they fail over a hundred times. To a novice the fact that it ignites and shows the proper resistance leads them to believe the coils are good but experience shows us over and over that it is a common issue.
It can be other things but start here because there cheap and they will fail sometime anyway.
Jimi
Please do not drink & drive
#8 tamfflcommissioner
tamfflcommissioner
  • 14 posts
Posted 02 August 2012 - 09:59 PM
Thanks all. I ordered the coils shortly after REG suggested them. They are already at the FedEx location.
I'll keep you posted.
Jeff
#9 tamfflcommissioner
tamfflcommissioner
  • 14 posts
Posted 10 August 2012 - 09:35 PM
Ok,
Coils arrived late Wednesday. I installed them yesterday afternoon, put the dryer back together and have now completed 4 laundry loads without a problem.
Thanks REG and the rest of the Appliantology Forum!
You guys rock.
-Jeff
#10 telefunkenu47
telefunkenu47
    Kohai
  • Appliantologist
  • 406 posts
Posted 12 August 2012 - 12:57 PM
psychic...
Even root canal is easy...if you're a dentist...
#11 JMelvin
JMelvin
  • 14 posts
  • Flavorite Brew:Sam Adams Winter
Posted 01 June 2014 - 02:49 PM
Hi All,
Dryer came down with the same problem again.
I reordered new coils and just installed them. Problem continues: dryer glows red, shuts off before igniting.
What is the next likely problem?
Same dryer as before:
Whirlpool Gas Estate Dryer - TGDX640JQ2
#12 JMelvin
JMelvin
  • 14 posts
Posted 01 June 2014 - 04:36 PM
Never mind. Gas is off. Smile.
    Shōgun
  • Master Samurai Tech
  • 31,139 posts
Posted 01 June 2014 - 05:03 PM
Been bitten by this one m'damnself once... but ONLY ONCE!
