Frigidaire Affinity Washer, door lock problem
4 replies to this topic
#1 Todd Tanner
Todd Tanner
  • 3 posts
  • Flavorite Brew:Surly Darkness
Posted 05 August 2012 - 12:09 PM
My washer stopped. (Frididaire Affinity) I trouble shooted until I determined that it is the door lock mechanism. What I cannot figure out is if it is the door lock, possibly the wax motor or the control panel not sending power to the door lock mechanism.
I have bipassed the switch so the washer thinks the door is closed and locked so I can run it for now, hopefully the door doesn't pop open.
The reason I am confused is because I cannot detect any voltage to the wax motor anytime during the cycle. Before I order a part I want to make sure it's what is bad.
Any suggestions?
Edited by Todd Tanner, 05 August 2012 - 12:09 PM.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 05 August 2012 - 12:25 PM
Washer model number ?
#3 Todd Tanner
Todd Tanner
  • 3 posts
Posted 05 August 2012 - 12:27 PM
ATF6000FS1
#4 RegUS_PatOff
  • 33,588 posts
Posted 05 August 2012 - 12:44 PM
... I cannot detect any voltage to the wax motor anytime during the cycle.
where are you trying to measure that voltage ?
should be between the Pink and the Red / Black wires
http://www.repaircli...tDetail/1531974
#5 Todd Tanner
Todd Tanner
  • 3 posts
Posted 07 August 2012 - 10:46 AM
sorry it took so long to get back to you. Yes I am checking voltage at the Pink and the Red / Black wires. I have the door lock assembly hanging out and I shorted out the two lines so the washer thinks the door is properly closed and locked. I haven't kept a meter on it for the entire cycle. Even if I remove 90% of the water a lot still splashes out. but I have checked it at different times in the cycle and have tested it in diagnostic mode with the door lock setting.
