Work van storage
fixit guy
Does anyone know where to buy the wire shelves like Sears uses in their work vans? If some Sears tech would give me the name of the manufactor I would be greatfull!!!
Thanks
Fixit Guy
  • Replies 6
  • fixit guy
  • Southern Appliance
  • certified tech group 51
Had to dig into the recycle bid....................Place called American Van.......Racks...............crash cages,.................refrigerant tank racks.................roof racks.........storage drawers............ wall bins..................gizmos to turn the service vehicle cab into an office................ Call 1.800.526.4743 ......or.......... www.AmericanVan.com....
Thanks for the reply. I called AmericanVan and they don't carry the wire shelving. I know that Sears has the dealer install the shelves but I can't find the manufactor of them. This is driving me nuts!!!!!!
I went to Lowe's & bought the wire closet shelves .
I installed them upside down , so that the lip was facing up .
i installed them using the rail mounting hardware so they can be adjusted or removed easily if needed .
That's a fantastic idea! Do you think you could post a photo or two of the inside of your van with the shelving, Brother Southern? And did the rail mounting hardware come with the shelving?
I'm looking at buying a Ford Transit next year (the Fixit Prius has well over 100,000 miles on it) and will install shelving in it.
I will try to post photos Tomorrow .
The mounting hardware comes separate .
And , it's not exactly cheap either .
But , it was the best option I could come up with at the time , and I am well pleased with the result !
BTW they will tote a load too !
Haven't broken or sagged one yet , even with motors on them .
I've got a Step Van now. All the aluminum shelving was manufacturer installed, they tell me. For once I have more than enough room.
