D7824706Q Icemaker how to install
22 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 295 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 06 August 2012 - 10:08 PM
I got this icemaker assy. but I dont see where the wire harness goes. Any help?
#2 RegUS_PatOff
  • 30,216 posts
Posted 06 August 2012 - 11:22 PM
does the Fridge have a model number ?
#3 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 07 August 2012 - 10:42 PM
JFC2089HES It is a Jenn-Air
  • 24,243 posts
Posted 08 August 2012 - 01:24 PM
Are you referring to the wiring harness as it connects to the ice maker module head or to the freezer wiring?
#5 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 09 August 2012 - 06:14 PM
I did get the icemaker installed customer just called said no ice. The old ice maker had a reading of 73 ohms betweem L & M, from the tech sheet I should get 4400 to 8800 Ohms. I suggested the customer defrost the freezer as the icemaker has been out for about 3 months, when I replaced the icemaker I did not notice the fill tube iced up. And on the original call I got approximatly 300 ohms between V & N. Which the external fill valve is checked between V & N, and that checks out. Any suggestions. No water entering icemaker.
Edited by richseattle56, 09 August 2012 - 06:19 PM.
#6 RegUS_PatOff
  • 30,216 posts
Posted 09 August 2012 - 07:05 PM
... reading of 73 ohms betweem L & M,
yes, if the ON/OFF Switch is OFF
#7 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 09 August 2012 - 07:34 PM
the on /off switch is on 74 ohms
#8 RegUS_PatOff
  • 30,216 posts
Posted 09 August 2012 - 07:57 PM
then the Switch is bad
http://www.repaircli...rtDetail/915772
Ice-Maker-Assembly-D7824706Q-00631398.jp
#9 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 09 August 2012 - 11:27 PM
OKay I already replaced the icemaker customer defrosted the fill tube still no ice, where to look next.
#10 RegUS_PatOff
  • 30,216 posts
Posted 10 August 2012 - 01:30 AM
#11 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 10 August 2012 - 04:13 PM
No that was the old icemaker, I guess I did not make that clear. So there is a new icemaker in the freezer. Where to check
#12 RegUS_PatOff
  • 30,216 posts
Posted 10 August 2012 - 04:23 PM
same tests as the "old" IceMaker ...
Do you have the tech sheet ?
  • 24,243 posts
Posted 10 August 2012 - 04:30 PM
How to test a Whirlpool modular ice maker:
#14 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 10 August 2012 - 10:09 PM
Tried to jump and nothing, that is a manual harvest. Only getting 1.6 V between L & N. Getting 0 ohms between V & N. Coustomer said when the icemaker went out it spit a bunch of water out on the floor, a couple gallons. Any ideas Model # JFC2089HES. Brand new ice maker. Is it possible the new icemaker is defective, The 1.6V is confussing.
Edited by richseattle56, 11 August 2012 - 12:58 AM.
#15 RegUS_PatOff
  • 30,216 posts
Posted 11 August 2012 - 01:13 AM
... 1.6 V between L & N
... 0 ohms between V & N
1) Fuse in the IceMaker Wiring Harness
http://www.repaircli...tDetail/1545244
2) 0 OHMs would indicate a short in the Water Valve or wiring (would cause Fuse to blow)
http://www.repaircli...tDetail/1071263
#16 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 11 August 2012 - 01:38 AM
Is there a way to test the fuse? The water when the icemaker stopped working an indication. The 0 ohms between V & N anything? Should I replace both?
Edited by richseattle56, 11 August 2012 - 01:39 AM.
#17 RegUS_PatOff
  • 30,216 posts
Posted 11 August 2012 - 02:08 AM
... Is there a way to test the fuse?
... The 0 ohms between V & N anything?
... Should I replace both?
1) do a continuity test on the (Black ?) wire of the Harness
3) yes, if your tests were done correctly
#18 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 11 August 2012 - 02:18 AM
The black wire and what else.
#19 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 11 August 2012 - 02:35 AM
I got 0 ohms between V & N
#20 RegUS_PatOff
  • 30,216 posts
Posted 11 August 2012 - 03:17 AM
the other end of the Black wire in the Harness adapter as shown in the picture
