Frigidaire gallery heavy duty stack unit
3 replies to this topic
#1 matlock
matlock
  • 2 posts
Posted 02 April 2005 - 01:40 PM
My Washer would not engage the spin cycle one day and you could smell something burning. I let it sit for a while and it has been working  since but seems to vibrate alot during spin cycle and seems to not be spinning as fast as before. It says it has a 2 speed motor. Is it possible my high speed on spin cycle burnt and if so how can I fix?
Thank you
  • 24,349 posts
Posted 02 April 2005 - 01:57 PM
Front loader or top loader?  And post your model number.
#3 denrayr
denrayr
  • 1,111 posts
Posted 02 April 2005 - 04:13 PM
ive had a few of the top loader frigidaire stacked sets where the motor start switch would stick in the run position.  if its a top loader you will need to catch it while it is failing and check the switch. as for the slow spin problem you need to check voltage at the motor.
RedRock Appliance Service
435-773-7838
www.redrockrepair.com
Serving St George and Southern Utah
#4 matlock
matlock
  • 2 posts
Posted 03 April 2005 - 06:49 AM
thank you, will check it out - it is a top loader
