Whirlpool Washer ATW4475XQ
7 replies to this topic
#1 gcw1
gcw1
    Yamabushi
  • 76 posts
Posted 07 August 2012 - 08:57 AM
Whirpool Model ATW4475XQ
Customer is not happy with the water temp, When you put it on hot/cold very little warm water comes.
it seems there is no change in water temp. on all cycles but the cold/cold. is there a way to get a hot wash with this machine? Also it says 2 speed combination what does this mean? I looked at the diagram and it only shows a 1 speed motor. I have gone to whirlpool's website but no manual is shown for this unit yet. Was this unit made just for the big box stores?
#2 RegUS_PatOff
  • 30,670 posts
Posted 07 August 2012 - 10:59 AM
... is there a way to get a hot wash with this machine?
... it says 2 speed combination what does this mean? I looked at the diagram and it only shows a 1 speed motor.
1) Control Panel shows Hot Wash option
http://www.repaircli...tDetail/1877838
2) RepairClinic and Sears show a 2-Speed Motor
wiring diagram shows 1-Speed
although, I've read somewhere that on Delicate Cycles, (etc)
that the Washer Motor runs / pauses / runs / etc
#3 gcw1
gcw1
    Yamabushi
  • 76 posts
Posted 07 August 2012 - 11:42 AM
It shows a hot wash but it allows cold to enter as well. No change in temp from hot, warm and cool.
That is the same diagram that comes with the washer and shows 1 speed. Do you know what this 2 speed combination means?
#4 RegUS_PatOff
  • 30,670 posts
Posted 07 August 2012 - 12:01 PM
... it allows cold to enter as well. No change in temp from hot, warm and cool.
... Do you know what this 2 speed combination means?
1) are the Hot and Cold Hoses reversed ?
2) it may be the run / pause / run ... may only be used for Delicate, etc
It may be only using the HIGH Speed on the 2-Speed Motor
#5 DADoESTX
DADoESTX
    Kohai
  • 262 posts
  • Flavorite Brew:Iced tea with a spike of earl grey
Posted 07 August 2012 - 04:26 PM
Two Speed Combinations is marketing-speak for the Delicate cycle running the intermittent agitation pattern. It does not explicitly say, nor does it necessarily mean, that the motor itself is 2-speed. This is a common "feature" on lower-end direct-drive brands and models (Roper, Estate, Amana, Kenmore 400 and 500 models, etc.).
#6 RegUS_PatOff
  • 30,670 posts
Posted 07 August 2012 - 04:29 PM
... RepairClinic and Sears show a 2-Speed Motor
although could be using only High Speed
#7 sh2sh2
sh2sh2
    Sōhei
  • 225 posts
  • Flavorite Brew:yeunling
Posted 07 August 2012 - 06:26 PM
back to the temperartur problem, these washers probably have the lowered hot temps with a ATC switch.
#8 RegUS_PatOff
  • 30,670 posts
Posted 07 August 2012 - 10:24 PM
that model uses the 4148 Temperature Switch
