59669272991 Fresh Food Warm
7 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 295 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 08 August 2012 - 11:55 AM
59669272991. This is a Amana. Does anyone know how to test the damper control? Of course I will check the defrost system, but customer sees no frost on back wall of freezer.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
  • Flavorite Brew:Killians Red
Posted 08 August 2012 - 11:57 AM
I have replaced a ton of evap fans in these as well...
#3 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 08 August 2012 - 12:12 PM
Customer hears the evap fan running.
Edited by richseattle56, 08 August 2012 - 12:13 PM.
  • 24,346 posts
Posted 08 August 2012 - 12:15 PM
Is it running at full speed? You need to get your eyeballs on that fan. Lots of times, these fans will just get lazy and look like they're running but they're not at rated RPMs. ==> http://www.repaircli...er=596.69272991
#5 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 08 August 2012 - 12:48 PM
I should feel a good amount of air coming out of the damper assembly, correct. If I dont check to see if the evap. fan is running at a good speed?
  • 24,346 posts
Posted 08 August 2012 - 12:57 PM
And make sure the damper is open (visual).
#7 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 08 August 2012 - 06:09 PM
When asking a customer over the phone if they see any frost on the back wall of the freezer, you can't always trust their opinion. The evaporator was a solid block of ice. Bad defrost thermostat.
Thanks for all your help.
#8 certified tech group 51
  • 1,988 posts
Posted 08 August 2012 - 11:50 PM
Thanks for the epilogue..........Ya git a warm and fuzzy feeling with a happy ending.... :bunny: ......
