Maytag Neptune MAH5500BWW Stops After Fill
1 reply to this topic
#1 Jodi McLeod- Crosby
Jodi McLeod- Crosby
  • 1 posts
  • Flavorite Brew:Ruby from McMenamins in Oregon
Posted 09 August 2012 - 03:02 PM
Maytag Neptune MAH5500BWW Stops After filling with water. I think it was overloaded when this happened but now it won't complete a cycle. The machine fills up with maybe 2 gallons of water and maybe 2 minutes into they process stops and then nothing else happens. The timer keeps counting down but the machine does not move further in the cycle. We found some advice online which told us to:
The easiest way to check the motor circuit is to take the front off but leave the door on and make sure it is closed. Go into diagnostic mode by pushing Delicate and Heavy soil at the same time. This will put you into diagnostic mode. Then hit the spin button on the board, display should change to 00 and possible start going up. If it stays at 00, go to the motor control board mounted on the right hand floor and do a voltage test at the harness coming to the board that has the White & Black wire. If your display is staying on 00 and you have 120VAC to this board your motor control board is bad and will have to be replaced with the new update kit listed below. If you do not get 120VAC or your display is changing to indicate RPM's, then additional tests will have to be made.
We've put the machine in Diagnostic Mode & Started the Spin cycle. We do get 120 VAC to the board and the display does stay at 00. From the advice above, it would indicate that we need to replace the Drive Motor with a new Drive Motor repair kit.
Is there anything else we should check before we make this purchase.
Here are the machines Model No. & Serial No.:
Model No. MAH5500BWW
Serial No. 71763129ZM
Also, why would this board just stop working?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 09 August 2012 - 03:12 PM
unless the Motor & Controller have already been upgraded
http://servicematter.../TCL-0014-B.pdf
This may be the kit you need
http://www.repaircli...rtDetail/949491
service manual
http://appliantology...nt-load-washer/
