resetting kenmore dishwasher after high water shut down
8 replies to this topic
#1 Murf
Murf
  • Chief Appliantologist
  • 18 posts
  • Flavorite Brew:Maple Syrup
Posted 10 August 2012 - 04:35 PM
Kenmore dishwasher, Model #665.13242K900 shut itself down due to high water caused by a clogged drain. I have removed the blockage and now need to reset the machine and need the sequence of button pushes that accomplishes this.
Murf
#2 RegUS_PatOff
  • 30,192 posts
Posted 10 August 2012 - 04:58 PM
Invoking Service Diagnostics clears all status and last ran information from memory and restores defaults
To invoke the Diagnostics Cycle, perform the following key presses or actions in less than 6 sec while in standby:
Heated Dry ➙ Normal ➙ Heated Dry ➙ Normal
#3 Murf
Murf
  • 18 posts
Posted 10 August 2012 - 05:40 PM
please explain "while in standby". The sequence has been executed in less than 6 seconds with no change in the status.
I must not be in "standby"?
#4 RegUS_PatOff
  • 30,192 posts
Posted 10 August 2012 - 05:51 PM
stand-by ...
D/W power ON, but not running
#5 Murf
Murf
  • 18 posts
Posted 11 August 2012 - 12:26 AM
Turning the power to the machine off and then on stops the blinking but the second that Heated Dry is touched the blinking starts again and will not stop until power is turned off and back on. Executing the sequence, Heated Dry⇒Normal⇒Heated Dry⇒Normal, in less then 6 seconds, appears to have no effect.
#6 RegUS_PatOff
  • 30,192 posts
Posted 11 August 2012 - 01:49 AM
... the second that Heated Dry is touched the blinking starts
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a “dead” keypad/console)
indicates one or more key switch lines are stuck or shorted on either the control or the keypad.
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 sec.
7. Close dishwasher door.
8. Monitor the control’s response:
➔If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on the Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
➔If the control is not OK (still sees shorts with the keypad unplugged), then the drain motor will NOT.
if the drain motor does not start within 10 sec, repeat or verify that all the steps were followed, then replace the control.
http://www.repaircli...tDetail/1795922
Black Keypad
http://www.repaircli...tDetail/1872702
 White keypad
http://www.repaircli...tDetail/1874822
Main-Control-Board-W10285180-01189322.jp
#7 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 894 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 11 August 2012 - 05:10 AM
Thermal Fuse ==> http://www.repaircli...0258275/1549751
Check the thermal fuse/bi-metal, first thing I check when dishwasher stops with water still in tub...
Edited by Mrs. Samurai, 12 May 2013 - 09:04 PM.
APP button producing misconfigured code. Need to fix this.
Mother Teresa
#8 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 894 posts
Posted 11 August 2012 - 11:10 AM
<--- Sorry, too many Dead Guys...
Missed that part earlier. more likely a keypad issue as RegUS_PatOff pointed out above.
Mother Teresa
#9 Murf
Murf
  • 18 posts
Posted 18 August 2012 - 02:26 AM
It was the key pad. I replaced it and all is good
Thanks for all of your help.
