Fisher&Paykel GWL15YS
2 replies to this topic
#1 SPYDA
SPYDA
    Ikkō-ikki
  • 54 posts
  • Flavorite Brew:Miller Lite
Posted 11 August 2012 - 10:16 AM
This machine had trouble draining. Error code 3-6-8, came up, blocked pump. Pump was seized up so replaced pump. Now no water enters the tub, it did for about 30 sec. then stopped. Water valuve tested good, and the thermistor in the water valuve i think tested good. Tested it in glass off cold water and then in hot water, the reading would rise and fall. Also now i cant get dieignos. code to work. Do you think its the control board? Help please...
#2 nickfixit
nickfixit
  • 2,190 posts
  • Flavorite Brew:Glen Livit
Posted 11 August 2012 - 05:16 PM
On some FP washers, a pump failure would also ruin the control board. Later models had an inline fuse between the pump and control to protect the control . If y0urs does not have an inline fuse intsalled on the red wire to the pump, right close to the main control, then you get to price the control and make a decision.
#3 SPYDA
SPYDA
    Ikkō-ikki
  • 54 posts
Posted 11 August 2012 - 05:34 PM
Thanks nick.
