kvh
kuds01flbl6 blinking clean light no tech sheet..
6 posts in this topic
kuds01flbl6 blinking clean light no tech sheet..Check heater and wiring but did not have tech with machine need tech sheet or service manual... Tried to reset by doing key dance high temp/ energy saver would light up lights but not reset... can not run to test further.
The control is looking for a temperature use in the water and no seeing it. Several things can cause this:
- no water in the basin
- bad heater circuit
- bad water circulation pump
If you've already verified the first two, then that only leaves the last one. Replacing the Motor pump assembly is the cure ==> http://www.repairclinic.com/PartDetail/Circulation-Pump/W10239405/1548519
How do you reset control
Press the following option keys in the sequence shown,
while the dishwasher is inactive
HIGH TEMP
(Power Scour)
AIR DRY
(No Heat Dry)
(Energy Saver Dry)
HIGH TEMP
(Power Scour)
AIR DRY
(No Heat Dry)
(Energy Saver Dry)
If heating problem is not corrected,
the control will stop running again on next cycle
Key dance gives all light light up with dim flickering clean light. When you hit cancel clean light starts flashing again...
