Kenmore 90 series washer does not rotate clothes
11 replies to this topic
#1 neilc88
neilc88
  • 4 posts
Posted 03 May 2005 - 07:50 AM
Well, the wife just called me at work and said the washer is making a grinding sound and not washing or spinning at all.:(  Any ideas what could be wrong?   I'm thinking clutch or gearbox. :? Any thoughts or ideas would be greatly appreciated.
It does fill and drain water properly.  Just no wash or spin mode.
    Shōgun
  • Master Samurai Tech
  • 30,618 posts
Posted 03 May 2005 - 10:11 AM
I'm thinking drive coupler.
#3 neilc88
neilc88
  • 4 posts
Posted 03 May 2005 - 10:16 AM
Samurai Appliance Repair Man,
Thank you for your response and link.  I will give it a look and report on my findings.  If the coupler is bad, is there any way to see if the gearbox is also bad?:violin:
    Shōgun
  • 30,618 posts
Posted 03 May 2005 - 10:24 AM
Yes, but it ain't easy. :grunt:
Go ahead and replace the coupler. The odds of a successful repair are overwhelmingly in your favor.:tokin:
#5 neilc88
neilc88
  • 4 posts
Posted 04 May 2005 - 02:52 AM
You were right on the coupling.:banana:  Is there anything else I should look for before replacing it?  I have small children.  Do socks or other items jam the bowl causing the coupling failure?  The washer is about 5 years old, family of 5.
    Shōgun
  • 30,618 posts
Posted 04 May 2005 - 09:57 AM
It's a normal wear item, like a belt.  It eventually breaks because of of friction and material fatigue-- part of the process of everything tending toward total entropy, in keeping with the second law of thermodynamics, as shown below:
#7 neilc88
neilc88
  • 4 posts
Posted 05 May 2005 - 10:32 AM
Thanks sooo much for your help.  The washer is back up and running.:banana:  The wife is off my a$$.:yikes:
    Shōgun
  • 30,618 posts
Posted 05 May 2005 - 02:45 PM
Glad to help! :dude:
#9 Lurker_tribaldragon_*
  • Lurking at the Threshold
Posted 08 May 2005 - 05:08 AM
Since Neil seems repaired and satisfied, I'm gonna hijack this thread. My washer is actually a 110.28902790 but it has direct drive. Coupler broke last year, replaced, worked fine. Now it broke again. The holes on the trans. side were worn out (little pile of rubber shavings underneath) and it sheared the posts off on the same side. The motor side looks fine except for the 1 missing post. But I think it was broken when the others snapped. Are we overloading it or do I need to look for a new washer?
    Shōgun
  • 30,618 posts
Posted 08 May 2005 - 05:15 AM
You're either overloading it or you damaged the coupler when you installed it.
Why would you even consider looking for a new washer simply because it needs a $15 part?  :silly:  If all I had to do to keep a washer going is replace a $15 part every once in a while, I'll do that every time before I go buy new washer.. and end up doing the same thing to it, or worse.
How much is a new one?
#11 Lurker_tribaldragon_*
Posted 08 May 2005 - 05:33 AM
Thanks for the quick answer! I just wanted to make sure this wasn't indicitive of impending trans failure, or something. And I will keep replacing this (buy 2 or 3) as long as I can. Thanks again, Samurai:D
#12 Samurai Appliance Repair Man
    Shōgun
  • 30,618 posts
Posted 08 May 2005 - 05:35 AM
Nolo problemo, compadre.  :smokin:
