Electrolux dishwasher EIDW6105S1A
Electrolux
2 replies to this topic
#1 Patricio
Patricio
    Kohai
  • Chief Appliantologist
  • 448 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 17 August 2012 - 12:02 PM
Dishwasher dead. Can set all cycles but unit will not run. Door switch has continuity. Will not go into relay test mode. LED,s at kick plate panel do not light up indicating a problem. Set any cycle & push start, unit sits with cycle button lit. after a few minutes all cycle LED's blink simultaneously. Something simple or something major. Service data sheet is not much help.
IgonFishn & Tight Lines
#2 RegUS_PatOff
  • 30,273 posts
Posted 17 August 2012 - 01:02 PM
http://appliantology...ice-5995516548/
#3 Patricio
Patricio
    Kohai
  • 448 posts
Posted 15 September 2012 - 10:41 PM
Installed back ordered control board in this 'nightmare' dishwasher last week, Unit is working like it should.
I have found out that diagnosing electronic problems is 90+% of the time spent on the repair & installing the new part is less than 10%, unlike mechanical repairs like diagnosing a leaking pump is <10% of time involved & installing the new pump is >90% of time involved.
But most of all back ordered parts are most time consuming 'cause the customer wants it fixed yesterday.
