Kenmore Washer 110.27092602
F1 error code
7 replies to this topic
#1 prairiestr
prairiestr
    Sōhei
  • Chief Appliantologist
  • 189 posts
  • Flavorite Brew:Jack
Posted 17 August 2012 - 04:29 PM
Washer starts/ stops, F1 error code flashes, Tech sheet says replace main motor control board, Help with part # please.
#2 RegUS_PatOff
  • 30,192 posts
Posted 17 August 2012 - 07:15 PM
F1 Pressure Signal Out-of-Range
F then 1 flashes when the control detects an out of range pressure signal.
➔ Check pressure hose connection from tub to machine/motor control.
Is hose pinched or kinked?
➔ If F then 1 repeats numerous times after POWER is pressed
and the pressure hose connection is not pinched or kinked,
replace the machine/motor control.
http://www.repaircli...tDetail/1469076
Main-Control-Board-W10189966-00704579.jp
#3 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 17 August 2012 - 08:40 PM
Reg, control shows F1, not F then 1. I may have read the tech sheet wrong, do you have a copy? Did not notice any problems with the pressure hose, also tub was empty and only small amuont of water came in before failure code. Customer says she can get it to start occasionally by pushing start repeatedly.
#4 RegUS_PatOff
  • 30,192 posts
Posted 17 August 2012 - 09:30 PM
previous post should have read:
F
. 1 Pressure Signal Out-of-Range
Tech Sheet - W10026571.pdf
link PM'd
#5 Budget Appliance Repair
  • 3,996 posts
Posted 18 August 2012 - 06:01 AM
What you are describing is almost always a bad control module, (I've never had it be any thing but a control module on the 3 or 4 that I have seen and worked on).
Whirlpool put out a tech bulletin on this F1 problem, (October 2008 L8178767).
Models: WTW6200S, WTW6300S, WTW6400S, WTW6600S, WTW6700T,
MTW6300T, MTW6400T, MTW6500T, MTW6600T, MTW6700T
Serial # range: CT01 - CU52
The bulletin basically says to check every thing to do with the pressure hose for moisture in the hose, holes in hose or kinked hose and to check the air bell for lint or any other debris.
And then last step if all checks OK, REPLACE THE CONTROL MODULE.
Edited by Budget Appliance Repair, 18 August 2012 - 06:10 AM.
William Burk (Willie)
Eureka, CA 95501
#6 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 18 August 2012 - 01:51 PM
Budget and Reg.,
Thank you for the info, I think I'm convinced the control module is bad. This is ser# CT 48....
Thanks for the help.
#7 RegUS_PatOff
  • 30,192 posts
Posted 18 August 2012 - 03:40 PM
8178767.pdf
#8 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 19 August 2012 - 04:56 PM
Reg.,
Thank you for the service pointer, great info.
I owe ya one.
Also tagged with one or more of these keywords: F1 error code
