Maytag Dryer Model LDE8416ACE blower fan loose
Maytag blower fan loose
3 replies to this topic
#1 senoiasummer
senoiasummer
  • 16 posts
  • Flavorite Brew:Don't drink
Posted 17 August 2012 - 09:27 PM
On the above model Maytag dryer (S/N 10534362SF) it started making a roar on start up and then (lateter) developed into a rattle that woudl go on continuously when drying. I finally motivated my self to remove the front cover and the sheet metal that holds the drum in place and discovered that the blower fan blade mechanism is loose on the shaft. It has play front to back as well as perpendicular to the shaft. There are three "slits" in the plastic collar that fits on the shaft, but it appears that they are there by design (i.e., not ragged edged ... they look like they were molded that way). So, what could cause this and what do I need to replace?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 August 2012 - 09:41 PM
Does it have the Snap-Ring and the Spring-Clamp ?
as shown in the video at about (time) 1:30
http://www.repaircli...tDetail/1245880
#3 senoiasummer
senoiasummer
  • 16 posts
Posted 17 August 2012 - 09:54 PM
yes it does. Both appear to be in ok condition
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,956 posts
  • Flavorite Brew:Killians Red
Posted 17 August 2012 - 10:26 PM
Then you just need to replace the wheel reg linked you...the old one is rounded out on the "D" shaft ...
