frigidaire microwave model fmv156dcc
door/latch alignment
2 replies to this topic
#1 tommytech
tommytech
    Sōhei
  • Appliantologist
  • 176 posts
  • Flavorite Brew:guiness
Posted 20 August 2012 - 01:44 PM
original problem was when set to cook,clock would count down and nothing else,no fan ,no heat,etc. seems like one of the door switches,right? well, all door switches and switch housing replaced at once, same problem. micro will work if door is pushed up on corner and held there. there does not appear to be any adjustment for door switches or door. go back tech said he "tweeked" lower door hinge to adjust, and that worked for about 4 days. same problem back again. all parts that were replaced wereoem, and all connectors to door switches were re checked.I've noticed the frame has some flex to it even when gently lifting door up and down.Seen this problem before with this same brand/model and customer ended up replacing micro. Any ideas?
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,944 posts
Posted 20 August 2012 - 07:15 PM
Bad hinges? Some customers have a tendency to lean on the door, bending the hinges.
Scott Wolf
#3 tommytech
tommytech
    Sōhei
  • Appliantologist
  • 176 posts
Posted 21 August 2012 - 05:53 AM
hinges look like they are spot welded to frame and not replaceable
