Dishwasher Kitchen Aid kuds25shali
8 replies to this topic
#1 arrow 1
arrow 1
    Sōhei
  • Chief Appliantologist
  • 115 posts
  • Flavorite Brew:Texas Tea
Posted 22 August 2012 - 06:16 AM
This d/w is not coming on. all lights on keypad work. tested door switch, thermal fuse all ok . put in diagnostic keypad will cycle each sequence, but no actual start of d/w? Could it be pump unit or do i need to do further diagnosis?
Edited by arrow 1, 22 August 2012 - 06:16 AM.
    Shōgun
  • Master Samurai Tech
  • 30,211 posts
Posted 22 August 2012 - 06:23 AM
Check for 120vac at P5 (gray wire) at the main controller when you first start a cycle. That's the voltage for the drain winding on the motor. If no voltage present, replace the main controller ==> http://www.repaircli.../8530929/940021
#3 arrow 1
arrow 1
    Sōhei
  • 115 posts
Posted 22 August 2012 - 06:41 AM
Will do thanks
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 August 2012 - 07:23 AM
does it Fill with Water ?
#5 arrow 1
arrow 1
    Sōhei
  • 115 posts
Posted 22 August 2012 - 08:55 AM
no it was full of water when it stopped
#6 RegUS_PatOff
  • 33,588 posts
Posted 22 August 2012 - 09:05 AM
if you (manually) empty it out...
will it Fill with water ?
#7 arrow 1
arrow 1
    Sōhei
  • 115 posts
Posted 22 August 2012 - 01:11 PM
no
#8 RegUS_PatOff
  • 33,588 posts
Posted 22 August 2012 - 01:19 PM
sounds like a bad Controller
#9 arrow 1
arrow 1
    Sōhei
  • 115 posts
Posted 22 August 2012 - 08:03 PM
Yes I think so as well. I am going to test for power at pin suggested thanks for helping.
