How to replace water inlet on KitchenAid Fridge Icemaker
Kitchen Aid Ice maker Water inlet fill tube KitchenAid
2 replies to this topic
#1 TerpFPE
TerpFPE
  • 15 posts
Posted 22 August 2012 - 08:57 PM
I have a KitchenAid Model KTRC19MKBL00 Fridge. I had ice build up that cause splashing of the water and ice build up on the freezer wall behind, and next to, the icemaker. Looking at the forums it seemed simple to replace the fill tube except, unlike all the others i have seen, mine has no external screws and none visible on the inside.
Attached is a picture of the back of the fridge and you well see the only screw is the water hose clamp. How does this tube come out and how to I make sure I order the correct replacement?
Hesitant
  • 24,719 posts
Posted 23 August 2012 - 06:33 AM
That's a really, really bad picture but I think I see a screw that you remove to loosen the clamp and then pull the tubing out.
Post a better photo that's IN FOCUS and another that's in context with the rest of the fridge and I can give you more clues.
#3 TerpFPE
TerpFPE
  • 15 posts
Posted 23 August 2012 - 12:03 PM
Please accept humble apologies for my lack of focus.
Also tagged with one or more of these keywords: Kitchen Aid, Ice maker, Water inlet, fill tube, KitchenAid
