thermistor wire-pin 2
wr55x10942
2 replies to this topic
#1 Fix It Once
Fix It Once
  • Appliantologist
  • 3 posts
  • Flavorite Brew:Columbian Coffee
Posted 23 August 2012 - 10:01 AM
I had a call on a refrigerator the other day and The SxS Ge refr. It had instructions to snip the thermistor wire in terminal 2. What was confusing was that " All bottom mounts were cut for sure " But, just below that in the same block, it gave a list of others with specific serial numbers. Can anyone tell me the way this is read....is it all bottom mounts including the serials listed or is it Any Others including SXS models with the serials listed. Very confusing.
Freedom Appliance / Aston, Pa
#2 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 163 posts
  • Flavorite Brew:guiness
Posted 23 August 2012 - 10:08 AM
do you mean the instructions that come with the motherboard?
#3 RegUS_PatOff
  • 30,201 posts
Posted 23 August 2012 - 11:30 AM
NOTE: This step is ONLY applicable for the following models:
All BOTTOM FREEZER models
(and any) ENCODER models with the following serial number prefixes:
TD2, VD2, ZD2, AF2, DF2, FF2, GF2, HF2, LF2, MF2, RF2, SF2
Also tagged with one or more of these keywords: wr55x10942
