GE stove - Model JBP80T0H1WW - Display dark, oven no heat, burners get warm
5 replies to this topic
#1 jkk
jkk
    Yamabushi
  • Chief Appliantologist
  • 98 posts
Posted 24 August 2012 - 08:01 PM
Wife tried to replace oven bulb. Start to remove socket (removed 2 screws), tried to put screws back in, heard pop. Now oven dead and display is dead, burners get hot.
Is there an internal fuse that might have popped?
#2 RegUS_PatOff
  • 30,262 posts
Posted 24 August 2012 - 08:37 PM
... Start to remove socket (removed 2 screws), tried to put screws back in, heard pop.
... Is there an internal fuse that might have popped?
1) :nono:
2) no, sorry
Electronic oven control, manufacturer has modified the connections on the board.
http://www.repaircli...tDetail/1974156
#3 jkk
jkk
    Yamabushi
  • 98 posts
Posted 06 September 2012 - 08:32 PM
Thanks.
Is there a separate part # for the cover (buttons, etc)? Or does that come with the cover?
#4 RegUS_PatOff
  • 30,262 posts
Posted 06 September 2012 - 09:16 PM
http://www.repaircli...tDetail/1086222
#5 jkk
jkk
    Yamabushi
  • 98 posts
Posted 15 September 2012 - 02:12 PM
Now the door on this oven is not closing correctly. I cannot get the right hinge situated inside the frame such that the door closes snug. I'also shown a picture of the left hinge, which appears to be operating correctly. Maybe the hinge is broken? Is there a trick to getting this right hinge back in correctly?
Attached File  011.JPG   112.33K   5 downloads Attached File  012.JPG   81.34K   4 downloads
#6 jkk
jkk
    Yamabushi
  • 98 posts
Posted 15 September 2012 - 06:11 PM
Ok, got the door back on. Took the hinge completely out of the oven, used pliers to extend the hinge, moved the clip to lock the door, put hinge back into oven.
