WHIRLPOOL GOLD Range YGY396LXPQ01
9 replies to this topic
#1 pc604
pc604
  • 4 posts
Posted 26 August 2012 - 02:09 AM
Hello everyone,
I have a Whirlpool GOLD electric range model #YGY396LXPQ01 w/ an electronic oven control that's not responding to my key presses.
Does anybody have a keypad matrix chart for this particular model? I would like to simulate touchpad entry by shorting the proper pins together to determine whether it is the touchpad or board that has failed.
Unfortunately it is not showing any F1 or F2 errors.
Thank you for your time.
P.S. Is the touchpad sold separately? From my google searches, I've noticed the touchpad comes in a 'control panel kit' that costs well over $200. If it's just the touchpad membrane I need, I would prefer just purchasing that separately.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 26 August 2012 - 07:02 AM
I can't find a matrix chart, but you can try this:
Recall last failure code:
press and hold the Off/Cancel key for 5 seconds
any part ordered from RepairClinic can be returned for a refund (less shipping)
including installed electrical parts
http://www.repaircli...tDetail/1394372
Touchpad-and-Control-Panel-W10122296-011
http://www.repaircli...tDetail/1061230
#3 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,574 posts
  • Flavorite Brew:What's on tap?
Posted 26 August 2012 - 07:04 AM
Unplug the keytail to see if you get the F2-E1 error, this will tell you if the control is sensing the keypad. The most common cause for control failure is corrosion on connectors. Check all connections before replacing components. And, no, the touchpad does not come seperately.
Edited by Chat_in_RI, 26 August 2012 - 07:12 AM.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect nor represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#4 RegUS_PatOff
  • 33,588 posts
Posted 26 August 2012 - 07:07 AM
... Unfortunately it is not showing any F1 or F2 errors.
#5 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,574 posts
Posted 26 August 2012 - 07:11 AM
I took it to mean there were no errors with the connections intact, remove the keytail and see if you THEN get an error code...
Edited by Chat_in_RI, 26 August 2012 - 07:11 AM.
Mother Teresa
Big Brother
#6 pc604
pc604
  • 4 posts
Posted 26 August 2012 - 04:29 PM
I already tried the "Off/Cancel" key for 5 seconds w/o any response :( In fact, I'm not getting any response from any of the touchpad buttons. I've tried a continuity test between the pins of the ribbon connector while going through all the buttons, and I get continuity here and there, but without a matrix chart, I have no way of knowing for certain.
One thing I do know for certain is I have 120v to my oven control board transformer, and it seems to be sensing my door switch just fine as the 'Oven Light Relay (K4)' clicks in on the board when I open the door. Also, I believe the 'DLB relay' (K5) is working as I hear that click in about 5-10 seconds after plugging the unit back into the wall. BTW, what does DLB stand for?
I had no idea RepairClinic has such a good return policy. Thanks for letting me know. At least I can return one of the parts if need be.
#7 pc604
pc604
  • 4 posts
Posted 26 August 2012 - 04:45 PM
Yes, it does give me a F2 error when I unplug the keypad connector. Nothing responds on the keypad though when plugged back in. I'm leaning towards the touchpad rather than the board, but I wish I could know for certain w/ a touchpad matrix. It's a shame they don't sell the touchpad standalone. IMHO, it's kind of a gouge to pay an extra $100+ for a front control panel I already have. Anyhow, thanks for the quick reply. BTW, a stupid question but I'm thinking Whirlpool doesn't disclose proprietary information such as touch pad matrix charts to the general public?
#8 Scottthewolf
Scottthewolf
    Senpai
  • 2,985 posts
Posted 27 August 2012 - 10:45 PM
DLB stands for double line break.
Are you sure somebody didn't hit the child lock button by accident?
Scott Wolf
#9 pc604
pc604
  • 4 posts
Posted 28 August 2012 - 09:16 PM
Good point Scott. Which button combinations for enabling/disabling child lock? I see the "start" button & "hold down button for 5 sec to lock". Would I do the same for unlocking?
#10 Scottthewolf
Scottthewolf
    Senpai
  • 2,985 posts
Posted 28 August 2012 - 09:24 PM
Yes, hit the same buttons to unlock.
Scott Wolf
