PFSS5NFXCSS Freezer -32, fresh food 54 degrees
2 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 420 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 27 August 2012 - 01:30 PM
My question is first off, can I use the mabe sheet on GE Electronic Refer Diagnostic to diagnose the sensor in fresh food? And there is no air coming out of the damper in FF compartment. My local part store has 100+ of the FF temp sensor in stock, usually when I see that many carried it has a high failure rate. and I also notice GE has mad e a sub for original part.
Edited by richseattle56, 27 August 2012 - 01:37 PM.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 27 August 2012 - 02:57 PM
Is the Damper "open" ?
Is the Evaporator (Freezer) Fan running ?
(when the Compressor runs)
Do you have the "newer style" Thermistors ?
http://fixitnow.com/...ed-thermistors/
#3 richseattle56
richseattle56
    Kohai
  • 420 posts
Posted 27 August 2012 - 04:00 PM
The evap fan running, damper open, and I dont know what type of thermistors. Its a defrost issue. The freezer thermistor, I belive. Need manual cant even get to back wall or remove the door .No tech sheet anywhere on fridge.
Edited by richseattle56, 27 August 2012 - 05:45 PM.
