Bosch Dryer Not Heating
4 replies to this topic
#1 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 29 August 2012 - 05:55 PM
Model# WTMC5321US/05 Complaint is not heating. Performed continuity,ohms, and voltages checks. Heater, T-Limiter, Belt switch and sensor ohm GOOD. Continuity is good as well. Sensor is good for ohmage. Voltage drops proved 120V is coming from motor, but not from the Board on TERMINAL X11-12 pins 10, and 9 thru the heating relay. Replaced the Board and Relay still no heat. I jumped out the heating relay and element fires up. What's the chance of the board being bad out of the box. There's only two outputs on the board one going to the motor and one going to the heating relay. What am I missing?
#2 jb8103
jb8103
    Kohai
  • Chief Appliantologist
  • 457 posts
  • Flavorite Brew:Ginger ale
Posted 29 August 2012 - 06:15 PM
If I understand you correctly, you're not missing anything, but may have a bad relay out of the box. The element works when the relay is isolated out.
First, do no harm.
#3 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 29 August 2012 - 08:56 PM
Correct I've also downloaded the manual and realized my 2nd leg of 120V isn't coming from the board. Looking at the schematic your probably right my relay would have to be bad because it supplies 120V to T Limiter which feeds element thanks for response.
#4 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 30 August 2012 - 11:56 AM
Bad board, out of the box!!!!!! My original post was correct I wasn't receiving 120 from the board. Lesson Learned NEVER SECOND GUESS OHMS LAW!!!!! Thanks again for response/help!!!!!!
  • 24,338 posts
Posted 30 August 2012 - 03:34 PM
Since we can't see 'lectricity, we just gotta trust our meters! Posted Image
