The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
Colint
Asko w660 blank display panel
5 posts in this topic
Hi
I have an Asko W660 with a display panel that suddenly went completely blank when putting in a load of washing. The red power light is still working, and the fuse looks fine, but the machine's completely dead otherwise. I had a look at the main control board, and that looks fine, no obvious damage. Same with the mains filter.
I have the wiring schematic, so tested the voltages on the board, and discovered that the voltage to the display panel is about 6V instead of 13V. I don't want to buy a new control board, as I don't think the machine's worth spending that much on, so I'm keen to investigate whether I can replace the transformer on the board? Problem is how to search for the part -- is it likely to be fairly generic, or will it be very hard to locate? I can send some photos if that helps...
If you're getting a good line voltage (120 VAC nominal) to the board and it's not outputting specified voltage, then the board is bad, slam dunk ==> http://www.repaircli...8076271/1154630
Yes. Are you getting good voltage to the dispplay board?
No. The voltage on the main board where it feeds the display is about 5V where is supposed to be 13V, so I assume the main board is faulty rather than the display board.
Colin
... and I'm getting good mains voltage to the main control board.
