Sonic
Bosch Dishwasher SHU4306UC/U06 runs and runs
4 posts in this topic
Well... The customers complaint is that the dishwasher will either fail to start or will run for hours. I checked the heater circuit to make sure that wasn't an issue and it wasn't. I then replaced the control board and also the on off switch as insurance. Well... The customer called me this evening to tell me that the dishwasher is still forever running. What am I missing? HELP
Did you really check to make sure the heater is really working? It is impossible to check if it is unless you put an amp meter on the on the black wire of the dishwasher in the junction box.
You should get about 8-10 amps if it is working and only about 1-3 amps if it is not working,.
Yes, before I replaced the board I had I believe 9 amps through the heater circuit
Ok. just checking.
