Whirlpool dryer won't dry! LER5636JQ0
18 replies to this topic
#1 beagle
beagle
    Ikkō-ikki
  • 36 posts
Posted 31 August 2012 - 05:22 PM
Please help! My dryer (model LER5636JQ0) has become a blower.
What do I do?
Thank you in advance for your help!
Beagle
#2 RegUS_PatOff
  • 30,229 posts
Posted 31 August 2012 - 05:28 PM
Has worked OK up for till now at this location ?
Have you re-set your House Circuit Breakers and / or
checked for 120v & 240v AC at the Dryer Terminal Power Strip ?
#3 beagle
beagle
    Ikkō-ikki
  • 36 posts
Posted 12 October 2012 - 08:11 PM
Runs just no heat. Heating element coils good, how do I check the thermostat?
#4 beagle
beagle
    Ikkō-ikki
  • 36 posts
Posted 12 October 2012 - 08:38 PM
Found the repair tip videos for the thermostat and heathing element. Tested both, and both have continuity. Now what? Please help.
#5 RegUS_PatOff
  • 30,229 posts
Posted 12 October 2012 - 08:55 PM
#6 beagle
beagle
    Ikkō-ikki
  • 36 posts
Posted 12 October 2012 - 09:01 PM
Yes, all has been done.
#7 kdog
    RoughShod
  • 7,428 posts
Posted 12 October 2012 - 10:01 PM
Locate and test the fuse by removing the rear panel of dryer - located on the lint screen housing - has 2 small blue wires - if open circuit, order and install new by clicking link:
http://www.repaircli...mber=LER5636JQ0
#8 RegUS_PatOff
  • 30,229 posts
Posted 12 October 2012 - 11:53 PM
... Locate and test the fuse ...
on electric Dryers, would prevent the Drum Motor from running .. (it runs) :whistling:
Does the Timer still run in the Auto-Dry (sensor) Cycle ?
check the Thermal Cutoff and the Hi-Limit Thermostat (thermal switches)
http://www.repaircli...PartDetail/2651
Thermal-Cut-Out-Fuse-Kit-279816-00630454
#8 & #15 in the diagram
#9 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 163 posts
  • Flavorite Brew:guiness
Posted 13 October 2012 - 12:03 PM
found a dryer yesterday,customer had selector set to "fluff" cycle.never heat that way. just sayin'
#10 beagle
beagle
    Ikkō-ikki
  • 36 posts
Posted 14 October 2012 - 09:27 PM
Tested the thermal fuse, has continuity. Now what?
#11 kdog
    RoughShod
  • 7,428 posts
Posted 14 October 2012 - 09:35 PM
Can you measure terminals of element for 240 VAC, while unit running in a heating cycle ?
#12 RegUS_PatOff
  • 30,229 posts
Posted 14 October 2012 - 09:38 PM
... Does the Timer still run in the Auto-Dry (sensor) Cycle ?
#13 beagle
beagle
    Ikkō-ikki
  • 36 posts
Putting heating element back in now, will test in just a moment.
#14 beagle
beagle
    Ikkō-ikki
  • 36 posts
Posted 14 October 2012 - 09:42 PM
No, it will just run for hours. Just blowing cold air.
#15 beagle
beagle
    Ikkō-ikki
  • 36 posts
Posted 14 October 2012 - 09:48 PM
Tested everything and couldn't find an issue. Flipped the breaker in the apartment again (third time) and it's heating now. Not sure if we fixed something accidently or if we have another issue.
#16 kdog
    RoughShod
  • 7,428 posts
Posted 14 October 2012 - 10:04 PM
If/When you require any future investimagatin' - Diagram will be here: http://appliantology...wiring-diagram/
#17 suampman
suampman
    Sōhei
  • Chief Appliantologist
  • 161 posts
  • Flavorite Brew:redbridge
Posted 15 October 2012 - 08:56 AM
If you are able, tighten the screws at the 240 volt breaker. Hot and neutral screws. Also with the breaker off, check the wires coming into the dryer and make sure they are tight. Hope this helps.
#18 kdog
    RoughShod
  • 7,428 posts
Posted 15 October 2012 - 12:11 PM
Added model number to topic title
#19 beagle
beagle
    Ikkō-ikki
  • 36 posts
Posted 15 October 2012 - 11:19 PM
Thanks for all the help you guys! Really appreciate it!
