  • Announcements
Sign in to follow this
Followers 0
beagle
Whirlpool dryer won't dry! LER5636JQ0
19 posts in this topic
Please help! My dryer (model LER5636JQ0) has become a blower.
What do I do?
Thank you in advance for your help!
Beagle
Has worked OK up for till now at this location ?
Have you re-set your House Circuit Breakers and / or
checked for 120v & 240v AC at the Dryer Terminal Power Strip ?
Runs just no heat. Heating element coils good, how do I check the thermostat?
Found the repair tip videos for the thermostat and heathing element. Tested both, and both have continuity. Now what? Please help.
Yes, all has been done.
... Locate and test the fuse ...
on electric Dryers, would prevent the Drum Motor from running .. (it runs) :whistling:
Does the Timer still run in the Auto-Dry (sensor) Cycle ?
check the Thermal Cutoff and the Hi-Limit Thermostat (thermal switches)
http://www.repairclinic.com/PartDetail/2651
Thermal-Cut-Out-Fuse-Kit-279816-00630454
#8 & #15 in the diagram
found a dryer yesterday,customer had selector set to "fluff" cycle.never heat that way. just sayin'
Tested the thermal fuse, has continuity. Now what?
Can you measure terminals of element for 240 VAC, while unit running in a heating cycle ?
... Does the Timer still run in the Auto-Dry (sensor) Cycle ?
Putting heating element back in now, will test in just a moment.
No, it will just run for hours. Just blowing cold air.
Tested everything and couldn't find an issue. Flipped the breaker in the apartment again (third time) and it's heating now. Not sure if we fixed something accidently or if we have another issue.
If you are able, tighten the screws at the 240 volt breaker. Hot and neutral screws. Also with the breaker off, check the wires coming into the dryer and make sure they are tight. Hope this helps.
Added model number to topic title
Thanks for all the help you guys! Really appreciate it!
Followers 0
