Site Search
To get started, click here.
GS6NVEXSL01 Ice Maker Auger problems
Auger Ice maker in door whirlpool
5 replies to this topic
#1 benzonaruckus
benzonaruckus
  • Chief Appliantologist
  • 19 posts
  • Flavorite Brew:no time, work and go to school 24-7. when i do, anything cold.
Posted 02 September 2012 - 02:28 PM
Hey guys, I have a whirlpool gold SxS ice maker with the bin in the door and the auger motor does not turn on. The shaft is fairly well rusted and wouldn't come out and was seized up(would not turn in either direction. CCW or CW) I did check for power to the motor but I wasn't getting 110 VAC but it seemed every time I pressed the button for the ice the ice flapper would come on and open, but the motor would not turn nor hum. My meter was registering a small amount in voltage change after I would call for ice, I just did not get very accurate readings.
I had the refrigerator on, door closed, and was testing the connection to the auger motor with the connection to the auger motor unplugged. Any ideas? By the amount of corrosion on the motor and the shaft not coming out I'm guessing maybe a replacement for the motor?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 September 2012 - 02:49 PM
... I wasn't getting 110 VAC
Auger Motor is 120v DC
#3 benzonaruckus
benzonaruckus
  • 19 posts
Posted 03 September 2012 - 07:58 AM
120VAC wasnt getting there either :confused:
#4 RegUS_PatOff
  • 33,588 posts
Posted 03 September 2012 - 08:02 AM
#5 benzonaruckus
benzonaruckus
  • 19 posts
Posted 03 September 2012 - 08:05 AM
Yeah, But isn't it 120VDC rectified inside of the motor?
#6 RegUS_PatOff
  • 33,588 posts
Posted 03 September 2012 - 11:38 AM
IDI Motor
Pins 1 & 2 = 10 to 15 Ω (thermal switch)
Pins 4 & 5 = 220 to 270 Ω (Motor)
Pins 4 & 5
120v DC (square wave)
polarity determines direction
Also tagged with one or more of these keywords: Auger, Ice maker, in door, whirlpool
