Fridgedaire Slide in Range FES355ESB top burners work no bake or broil
4 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 419 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 02 September 2012 - 03:51 PM
Fridgedaire Slide in Range FES355ESB top burners work no bake or broil. Oven sensor, bake and broil elements all good. So the only other thing it could be is the control, right.
Rich
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 September 2012 - 04:10 PM
... the only other thing it could be is the control, right.
yes, or one of the (soldered) Relays on the board
Have you recently used Self-Clean ? :nono:
http://www.repaircli...tDetail/1554352
Oven-Control-Board-318414214-01203017.jp
#3 richseattle56
richseattle56
    Kohai
  • 419 posts
Posted 02 September 2012 - 04:19 PM
No customer said he has never used the self-clean. Do you have any clues on how to get to the control?
Edited by richseattle56, 02 September 2012 - 04:26 PM.
#4 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,047 posts
Posted 03 September 2012 - 06:02 AM
Remove the surface control knobs and remove the four nuts, (one under each knob). These hold the control panel face onto the range, they do not hold the surface control switches in place.
Once the four nuts are removed the control panel face will lift out and you can remove the screws holding the panel that the switches and controller are mounted to. If I recall correctly and from the looks of the parts breakdown above I believe the controller screws are on top so you won't even have to remove the panel under the control face to remove the controller.
Edited by Budget Appliance Repair, 03 September 2012 - 06:06 AM.
William Burk (Willie)
Eureka, CA 95501
#5 richseattle56
richseattle56
    Kohai
  • 419 posts
Posted 13 September 2012 - 04:31 PM
That did work. Sorry I did not update earlier. The top panel came off easily after removing the four nuts. Replaced board, all is well. The nuts are reversed from parts diagram. They have a slot in them that you need to rotate counter-clockwise to remove.
The board was burnt.
Thanks for all the help.
Rich
Edited by richseattle56, 13 September 2012 - 04:35 PM.
