Whirlpool ED25PEXHW00 icemaker leaking out dispensor door
3 replies to this topic
#1 mr 409
mr 409
    Ikkō-ikki
  • 26 posts
Posted 03 September 2012 - 11:55 AM
Whirlpool ED25PEXHW00 side by side leaking water out ice dispensor door. Water seems to go into ice tray and then overfloow into ice bin and freeze on bottom, then will make it to the dispensor door and leak out due to thawing.
Link to photos
https://picasaweb.go...feat=directlink
Edited by mr 409, 03 September 2012 - 12:15 PM.
I never gave anybody hell, I just told the truth and they thought it was hell. - Harry S. Truman
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,953 posts
Posted 03 September 2012 - 01:38 PM
Try replacing the water valve first. If it still leaks you will need to replace the icemaker as well.
http://www.repaircli.../2206123/786533
http://www.repaircli...ly/4317943/1857
Scott Wolf
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 03 September 2012 - 02:26 PM
Is the Fridge water supply connected to an external filter ?
Reverse Osmosis system, etc ?
Is the Fridge water line connected to the House Water Pipes with a "saddle Valve" ?
Is it a "self-piercing" or "drill type" Valve ?
Too low of water pressure can also cause you symptoms.
#4 mr 409
mr 409
    Ikkō-ikki
  • 26 posts
Posted 03 September 2012 - 03:20 PM
The fridge has a filter in it but no other external filter.
Water supply is a "saddle valve" but is connected via a brass connection, not self piercing.
Water pressure elsewhere in house in fine.
