Frigidaire FRS26F4cq0 defrost heater connecting plugs
23 replies to this topic
#1 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 03 September 2012 - 09:50 PM
Thanks to the flowchart I'm trying to test the defrost heater first and haven't been able to unplug the part. I don't want to cause more problems than I've got already. I can't see the plug well enough to see if I can pry at the connection. Is there an area I should be pushing in like a release tab or something? Will it hurt anything to grab ahold of each side with pliers and pull?
Is the power supply side a female connector that I should worry about crushing if I use pliers? I'll be greatful for any help/suggestions to help me move forward with this.
Thanks.
#2 Scottthewolf
Scottthewolf
    Senpai
  • Appliantology Fellow
  • 2,820 posts
Posted 03 September 2012 - 10:05 PM
Click on the link and it will show you where to pull the connectors apart.
http://www.repaircli...03918255/833635
These defrost heaters rarely fail. Usually the problem is the defrost thermostat.
http://www.repaircli...03918214/892545
Scott Wolf
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 03 September 2012 - 11:21 PM
no need to disconnect anything (besides power) in order to do an OHM test on the Defrost Heater
#4 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 04 September 2012 - 01:07 AM
Scott, I see where the plugs(heater) are and have tried to pull them apart with no luck. Can I grab the two sides w/pliers and pull w/o messing anything up? and should I test the thermostat first? if it's bad, should I still test the heater? Thanks.
and RegUS_PatOff How can I check w/o disconnecting. There isn't a plug to probe like in your video. Thanks
#5 RegUS_PatOff
  • 33,588 posts
Posted 04 September 2012 - 08:03 AM
... How can I check w/o disconnecting.
probe into any of it's Connectors or at Defrost Board w/ or without removing the Connector
Have you tried doing a forced Defrost mode ?
#6 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 04 September 2012 - 07:30 PM
RegUS_PatOff , Thanks again for your response. I've just read up on the forced defrost in the service manual and I'm headed to do that now.
#7 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 06 September 2012 - 03:06 AM
I finally found the place to probe to test the therm. & defrost heater. If I had bent over further earlier, I would have seen the multi wire plug kinda pushed up high above the therm. When I tried to force the defrost with the light switch, I got nothing.
Thanks, again.
#8 RegUS_PatOff
  • 33,588 posts
Posted 07 September 2012 - 08:10 AM
If the Defrost Heater and the Defrost Thermostat Switch test OK,
then sounds like a bad Defrost Controller
http://www.repaircli...tDetail/1614983
#9 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 08 September 2012 - 05:03 PM
Tonight will be my third night to try to remove the left side back screw in the frig side to get to the ADC. The others came out easily w/ a 1/4" nut driver but I can't seem to get it seated on this one. Any suggestions? Surely it's the same size head, right?
Going back in...I've gone too far to give up now.
I'm fortunate to have an extremely old(from the 50's) Admiral that is helping keep some of the essentials cold.
#10 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 800 posts
Posted 08 September 2012 - 07:12 PM
The back screw will require a narrower 1/4" socket with extension.
#11 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 09 September 2012 - 01:35 AM
Thanks. I've tried several different 1/4" sockets I have and they're all too fat. I'll go shopping for another tomorrow.
Thanks, again.
#12 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 16 September 2012 - 11:16 PM
Bought a socket that fits into the area last Monday, Thursday, a new meter. Gave myself a break for a bit and now I'm headed to order the defrost control board.
I appreciate the help I've gotten here. It's a sanity saver.
Thanks.
#13 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 800 posts
Posted 16 September 2012 - 11:41 PM
Good Luck!
#14 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 23 September 2012 - 04:16 AM
The ADC arrived today. Yaay! That was the good news. The bad news is that I can't get the front piece where the freezer section/frig. section control knobs are located to come down. The service manual mentions a screw where the filter is but there isn't one. Other than that I've removed all the screws I can find and it's holding on tight. I've taken pics so I can look more closely but I'm not recognizing any clips but I'm guessing I just don't know what I'm looking at/for.
Will someone please direct me in this.
Thank you. Joanna
#15 RegUS_PatOff
  • 33,588 posts
Posted 23 September 2012 - 06:53 AM
#16 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 29,162 posts
Posted 23 September 2012 - 07:09 AM
Movie time!
#17 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 04 October 2012 - 03:06 AM
Installed ADC ...still wasn't right. I wasn't confident about my thermostat testing so I ordered one that I received today. Chose to test it before installing and it isn't showing continuity. :banghead: I have lowered the temp of the ice/water the therm. is in to 24' but still nothing. I've used all the ohm settings, switched the leads back and forth, any variation I can think of....just in case. Tried my old meter, too. Watched the therm. testing video numerous times, thanks for that help, too.
Any thoughts, suggestions or is there nothing else and I should just go ahead and ship it back for an exchange?
More thanks. Joanna
#18 RegUS_PatOff
  • 33,588 posts
Posted 04 October 2012 - 04:33 AM
... the ice/water the therm. is in to 24' but still nothing.
original Defrost Thermostat closes at rated 25F
may need to get it colder
OR possibly replacement Thermostat is rated colder...
Ice water won't get colder than 32F (it would freeze) unless you add some salt
Just install the new parts and wait for a few days. ...
#19 heylindy
heylindy
  • Grasshoppah
  • 12 posts
Posted 04 October 2012 - 05:39 AM
Thanks for the quick reply. I'll install when I get up in a few hours. I had added salt when I made the crushed ice slush and it hadn't gotten any colder than 24' when I started kickin' back about an hour ago. And thanks for mentioning those original temp.numbers i hadn't found anything mentioning those and the video had used 30' as an example.
Have a good day.
Joanna
#20 RegUS_PatOff
  • 33,588 posts
Posted 04 October 2012 - 08:08 AM
... original temp.numbers i hadn't found anything mentioning those
FRS26F4CQ0
tech sheets
240389610.pdf
link PM'd
