GE Condenser Fan RPM @ startup
GE Condenser Fan
3 replies to this topic
#1 geoc
geoc
  • 8 posts
Posted 04 September 2012 - 05:29 PM
I have GE refrig model #PFS22MISBBB. Not having had the benefit of seeing the CF Motor operate at factory specs I am wondering: 1) does the CF Motor come on immediately full speed when the compressor starts up or 2) does it run full speed all of the time, or 3) does it not come on untill a coil temp level is reached and then runs full speed or perhaps at mulispeed depending on coil temp.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,966 posts
Posted 04 September 2012 - 11:32 PM
It should come on immediately at full speed when the compressor comes on and shut off when the compressor shuts off.
Scott Wolf
    Shōgun
  • Master Samurai Tech
  • 30,708 posts
Posted 05 September 2012 - 06:06 AM
The dinky condenser fan motors are famous for running below rated speed causing increased compresser head pressure and increased compartment temperatures. ==> http://www.repaircli...ber=PFS22MISBBB
#4 geoc
geoc
  • 8 posts
Posted 05 September 2012 - 09:14 AM
Thanks much. I have purchased a new C F Motor from Repair Clinic but now find that the PWM input signal from the MB is not functioning correctly. Anyone care to guess how long the C F Motor will last after I rig it to run 24/7?
Thanks again... :thumbsup:
