Sign in to follow this
Followers 0
bogreen
Whirlpool Duet Washer Model #GHW9150PW1
5 posts in this topic
This washer is showing an F 06 error code.
I ran the diagnostic test and all checked fine.
The manual under the machine says to check wiring at motor and motor control and cpu.
All checked fine.
I did notice the spin never really got up to a "jet engine" speed before it shut down with an F 06 code.
Then I ran it on Drain and Spin and it drained and started to spin about 10 minutes and at the 2 minutes left mark,
it stopped, and flashed F 06
Motor bad? or maybe Motor Control board?
Bruce
has this Washer worked OK up till now at this location ?
OR has been transported from another location ?
same location since they bought it about 8 years ago
I have the exact same problem.
the code looked like F06 but it was actually F6E1, which is not the same as F06. The tech who came back today with the parts the first on e ordered said you ignore the 0, read it as F6 and add the E1 that flashed after the F06 to get F6E1. F6E1 is in the book and is something about the MMU not being in communication.
The MMU was blown. One of the bllack "chips" was actually blown apart and another spot on the board was burned enough to scorch the plastic cover. The first tech, not having read the code correctly, never even opened up the MMU cover to see the obvious problem.
Yes, I have the washer plugged into a high quality surge protector and no, we had no lightning or noticeable power fluctuations before this happened.
Fortunately for me it was under warranty.
While it was opened up, I checked the strainer and was very pleased to see that after 9 months there was only a tiny bit of lint and a quarter in it. I've always been worried about this unit not having easy access to the strainer.
Edited by DC950
Followers 0
