llky
Wolf gas range CH-4-29-FT22L
4 posts in this topic
Have this Wolf gas range model no. CH-4-29-FT22L that I need help with.First off it is an older range with standing piolets.Two of the top burners won't lite from the piolet,but you can lite them with a match.I have cleaned the burner heads and the little tube from the piolet flame to the burner head,but still not lighting.Also the oven burner needs a new thermocoupler.Can you supply a service manual or any info on this old range?Thanks for your time.
there is nothing to this range , normal in every way
the manual is not going to help you with the problems you have
the thermocuple is just a regular one like you would find in a old gas heater , home depot should have one
as far as the burners not lighting , you just have holes in the main burners plugged up , look for little holes that face the pilot tubes and clean them
