Frigidaire Freezer GLFU2067FW2 - CE error code
CE error code Frigidaire Freezer
9 replies to this topic
#1 deanfaw1
deanfaw1
    Yamabushi
  • 66 posts
Posted 05 September 2012 - 08:19 PM
This simple freezer is driving me crazy because it's usually the simple crap that throws us for a wild goose chase. The CE error keeps comming up and the unit just beeps. I tried resetting it both at the display board and via a hard reset. Nothing worked. The freezer is at proper temp 0F on the dot both on my meter and the display. I'm thinking the CE is for communication error but I could be wrong. It say opperational error on the error code sheet contact technician. Evap fan runs compressor runs fine. Anyone ever run into this issue before? I replaced main pcb and display pcb and still have the same error. Please help.
Dean
#2 RegUS_PatOff
  • 30,203 posts
Posted 05 September 2012 - 08:46 PM
does the display alternate between CE and the temperature ?
Does it also beep every 5 seconds ?
Does the Alarm / Reset turn the beep OFF ?
#3 deanfaw1
deanfaw1
    Yamabushi
  • 66 posts
Posted 05 September 2012 - 08:52 PM
Yes. All of the above.
#4 kdog
    RoughShod
  • 7,428 posts
Posted 05 September 2012 - 10:42 PM
Check for broken wire in the door between the lower hinge and the control
#5 RegUS_PatOff
  • 30,203 posts
Posted 05 September 2012 - 11:12 PM
User interface display shows “CE”.
This indicates a communication error between the user interface and electronic module.
1. Check the connectors in the wiring between the user interface and electronic module.
2. Replace the user interface.
3. Replaced electronic module.
4. Re-check the wiring
5. Replace the Door.
#6 certified tech group 51
  • 1,972 posts
Posted 06 September 2012 - 09:33 AM
I will double down with kdog..... ( look close at the zip tied wire harness )...........Some where out there, there are some pictures of a repair I done did on this type of failure.....Gotta figure out how to find 'all posts started' by poster, cuz it was a while ago................The first repair I performed for this failure, all I did was, replaced the wires from the control box to the display and taped the display to the rear of the unit..( freezer is in the middle of the floor at the end of a counter )...
#7 kdog
    RoughShod
  • 7,428 posts
Posted 07 September 2012 - 12:21 AM
http://fixitnow.com/...orfreezer-door/
#8 deanfaw1
deanfaw1
    Yamabushi
  • 66 posts
Posted 09 September 2012 - 09:18 PM
thanks guys I will take this advice out to the field to finish this job off. I have a sneaky suspicion that there is a broken wire at the zip tie underneath the door hinge. I will track this problem down. I will let you know. Thanks,
Dean
#9 deanfaw1
deanfaw1
    Yamabushi
  • 66 posts
Posted 25 September 2012 - 03:51 PM
Thanks guys it was a broken harness inside the door. The control panel is now at the toe kick location on the far right side. Owner approved work around. Thanks guys.
  • 24,220 posts
Posted 26 September 2012 - 05:46 AM
Clever fix! Would love to see a photo if you have one.
