  • Announcements
ApplianceDoctor
GE Washer Motor Brake
7 posts in this topic
I have GE washer that will not spin or agitate. Checked flashing light on inverter and light blinks once then pauses for 7 seconds. Tech paper says if you have 1 flash and long stop time to replace motor (brake). I checked with supply house and they tell me that there is nothing listed on the parts brake down as a motor brake. Does anyone out there have any helpful information.
Appliance Doctor
first, try this:
To clear errors, disconnect power until an audible clicking sound is heard (approximately 15 seconds).
Open and close the lid 5 or more times in any 12-second period within the first 30 seconds of power-up.
Errors will not clear if washer is in either agitate or spin mode.
otherwise
http://www.repairclinic.com/PartDetail/1567334
The tech sheet said to replace the motor brake. What part is and where is the motor brake?
I have GE washer Model# WJRR4170G1WW. Tech said to replace motor brake. Where is and what part is the motor brake? The parts supply house said they didn't see anything listed or called a motor brake.
do you mean clutch assy?
This is an inverter motor washer...brake is electronic and is part and parcel of the motor assembly ....$$$$.
do you have a flashing code on the led on the motor?
have you tried to clear it? (Unplug 5 min, plug in and lift and close lid 6 times within 30 sec of power up):
