Whirpool electric dryer, very hot vent last cycle now very low heat.
12 replies to this topic
#1 spoll
spoll
    Ikkō-ikki
  • 58 posts
Posted 10 September 2012 - 04:03 PM
First let me start off by saying this dryer is 5 years old and was originally hardwired until today. The black wire burnt out last week and I had my electrician come in and replace it with a plug, a terminal block with terminations and wall outlet. Dryer seemed to be working fine after he left and then I ran the dryer again and noticed that the aluminum vent was getting very hot. I also smelled a little burned rubber for 30 seconds when I originally turned it on but I thought it just might have been a residual smell from the last time it burnt out. As an aside, I switched the door opening hinge from right to left just to make it easier to load from the washer(I know, it only took me 5 years to figure it out.) Anyway, I put in a load and started the dryer and all I'm basically getting is faint heat.
The vents are clean btw, vacuumed and everything. Any thoughts? thanks.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 September 2012 - 05:10 PM
... noticed that the aluminum vent was getting very hot.
... I put in a load and started the dryer and all I'm basically getting is faint heat.
... vents are clean btw, vacuumed and everything.
Model number ?
Have you re-checked & re-set the House Circuit Breakers ?
Then checked for 120v & 240v at the Dryer Power Cord Terminal Strip ?
The Heating Element may be partially shorted to chassis (ground)
#3 spoll
spoll
    Ikkō-ikki
  • 58 posts
Posted 10 September 2012 - 05:40 PM
Model#WED5200tqo
I've re-set the circuit breakers.
I haven't because I really don't know how to test that. I thought the electrician would have performed that, no?
Btw, I purchased this dryer 5 years ago after asking for rec's on this site. I was told it would be a great trouble free, easy to repair dryer and I have to say that it's been anything but. Very frustrating.
#4 RegUS_PatOff
  • 33,588 posts
Posted 10 September 2012 - 05:46 PM
.. I thought the electrician would have performed that, no?
... ttrouble free, easy to repair dryer and I have to say that it's been anything but.
Voltages at the Dryer Terminal Strip may now be bad
... easy to repair IF you have the basic tools and a multi-meter for testing voltage and electrical parts inside the Dryer
#5 spoll
spoll
    Ikkō-ikki
  • 58 posts
Posted 10 September 2012 - 05:55 PM
I have the basic tools and I can borrow a multi-meter.
Should I just go to youtube and research how to fix the short and replace the dryer terminal strip?
#6 RegUS_PatOff
  • 33,588 posts
Posted 10 September 2012 - 06:23 PM
... research how to fix the short and replace the dryer terminal strip?
... how to test the Heater Element for a short
and Terminal Strip voltages
#7 spoll
spoll
    Ikkō-ikki
  • 58 posts
Posted 10 September 2012 - 09:21 PM
Ok, here's a new development. When I run the dryer without any clothes inside, the aluminum vent gets extremely hot, yet when I put a load of clothes inside the vent barely stays warm. Does that make sense?
#8 RegUS_PatOff
  • 33,588 posts
Posted 10 September 2012 - 09:24 PM
sounds like an air-flow problem ..
try a load with the Vent disconnected ..
Posting actual Vent temperatures would be helpful
#9 spoll
spoll
    Ikkō-ikki
  • 58 posts
Posted 10 September 2012 - 09:27 PM
Ok I will. One thing though, the top of the dryer is always cool to warm. I thought a hot top of the dryer meant an air flow problem and the vent needed cleaning, no?
#10 RegUS_PatOff
  • 33,588 posts
Posted 10 September 2012 - 10:16 PM
What are the Vent temperatures ?
Check the Vent air temperature at the back of the Dryer using a probe-type thermometer.
 $ 2.99 sometimes on sale
Dryer Vent:
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#11 spoll
spoll
    Ikkō-ikki
  • 58 posts
Posted 11 September 2012 - 10:18 AM
I'll do this tonight or tomorrow and get back to you, thanks for your help.
#12 spoll
spoll
    Ikkō-ikki
  • 58 posts
Posted 11 September 2012 - 04:42 PM
Well Sir, you were correct! It is an air flow problem. I did a small load of rags, disconnected the rigid aluminum vent tube attached my wife's pantyhose to the end and attached a thermometer. The end of the vent is about the same height as the dryer so I allowed for a few degrees of temp loss and it averaged about 140 through high heat and dried the rags in about 20-25 mins.
So thanks for your help and now I'm off to Angie's List to find a reputable vent cleaner in my area!
#13 Scottthewolf
Scottthewolf
    Senpai
  • 2,975 posts
Posted 11 September 2012 - 09:32 PM
www.dryerventwizard.com
Edited by Scottthewolf, 11 September 2012 - 09:33 PM.
Scott Wolf
