Amana Dryer ngd7200tw
3 replies to this topic
#1 Derik
Derik
    Sōhei
  • Master Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 11 September 2012 - 02:34 PM
was receiving ts code, checked thermistors all aok ! need service manual to clear ts code, so dryer will work again!!! any help would be appreciated!!!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 September 2012 - 06:34 PM
tS
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
- Check for diagnostic code 1
Clearing Diagnostic Codes
To clear the diagnostic code list press the
Sensor Dry Level and Time keypads together for 3 seconds
while viewing the list.
The cycle count for each diagnostic code will be reset to 0,
but not the machin cycle count.
will PM the tech sheets later
Tech Sheet - W10162408.pdf
#3 Derik
Derik
    Sōhei
  • 239 posts
Posted 11 September 2012 - 09:05 PM
I'll give it a shot! Your the bomb Reg THANKU!!!! could still use tech sheet for future reference and in case there's still a issue!! Everything checked out ok though thermister 10.65@ room temp! I received dryer and when went to test it out got the ts code after it ran for about four seconds??? No vent hooked up and no open sensors??
#4 RegUS_PatOff
  • 33,588 posts
Posted 11 September 2012 - 09:17 PM
link PM'd
