LG WM0642HW OE error. Does drian but very slowly.
5 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 418 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 11 September 2012 - 03:51 PM
Washer drains but very slowly. Nothing in drain hose. Drain pump motor messures 20 ohms. 120V at main board.
Anyone got any ideas.
Thanks'
Rich
    Shōgun
  • Master Samurai Tech
  • 30,577 posts
Posted 11 September 2012 - 04:04 PM
Check the drain pump impeller for gookus jamming it. Then blow through the drain hose to make sure it's clear. If all that's good, replace the drain pump ==> http://www.repaircli...EA2001T/2003273
#3 richseattle56
richseattle56
    Kohai
  • 418 posts
Posted 11 September 2012 - 04:19 PM
I check all that, and did all that. In the service manual it says.
"Is the coil of the drain pump too high or low?
(resistance of coil is 10-20Ω)"
"Yes"
"Replace the DRAIN PUMP ASSEMBLY"
Is the resistance suposed to be 10- 20Ohms or is it if you get 10-20ohms, replace the drain pump?
The hose is clear, nothing in impeller.
The drain motor? Thats what Im thinking.
Edited by richseattle56, 11 September 2012 - 04:19 PM.
    Shōgun
  • 30,577 posts
Posted 11 September 2012 - 04:20 PM
Replace the drain pump.
#5 richseattle56
richseattle56
    Kohai
  • 418 posts
Posted 11 September 2012 - 04:30 PM
Thank wwill do.
#6 richseattle56
richseattle56
    Kohai
  • 418 posts
Posted 13 September 2012 - 03:41 PM
Took the drain pump motor out, and the impeller was ground down to nothing compared to the new one. Something got through the trap and chewed it up. People check those pockets, before doing wash. Replaced pump motor drained in about a minute and a half, all is well.
Thanks for all the help.
Rich
